Introduction: 3D LAYERED BATMAN PICTURE DISPLAY
So while bored on Sunday I decided to pick back up a project I've been working on for some friends kids...
3D effect pictures, these can be absolutely anything, and can really change the dimensions of a photo literally lol
So enjoy the instructable
Step 1: You Will Need
Now first you will need your photo or picture, you can add as many layers as you want but for the sake of this Batman 3D picture I chose 3.
The idea of this is to use one for the background, one for the middle ground ( slightly cut out in areas ) and 1 for the fore ground ( cut out a lot to highlight your main focus.
For this I used
Photo Printer
x3 copies of the same image on A4 photo paper
Exacto Knife, scissors, precision cutting tool
Glue
Thick Card or foam ( I didn't have any to hand so stuck multiple layers together
Step 2: Get Cutting.......
Firstly look at your image and work out where to make your cuts and how it will work
Remember the first picture will not need to be cut at all
The second picture will need trimming in areas. I chose to remove the outline of the building and the sky to really make the building look 3D
The last picture I removed everything as you can see apart from Batman himself and the ledge is was sat on, and also took extra care to remove sections around the cape etc,
Hopefully the pictures will give you an Idea.....
Step 3: Sticking......
Once you have finished cutting and are happy, cleaned up all edges you will be ready to glue.
Due to the Photo paper being thick and card like itself it is very good and sturdy. I stuck some squares of cut out foam pieces left over from a previous project together creating a 0.5 CM block. Then using super gule stuck there to the back of the middle and fore ground.
Then comes the tricky park, lining up the middle with the background and sticking them on top of each other, followed by the top piece to for all 3 3D layers
Step 4: Finished......
Now when all dry your finished......
You can either mount these on card and canvas to give great results or even use in a thick box frame and give as gifts or put on your wall......
Hope you all like and great creative
