Introduction: 3D Model House
In this project we will make a house layout on 3ds max. You will need the application as well as most of the features of the application available to you.
Step 1: Walls of the House
First you will want to make the whole outside of the house such as the walls seen in the picture. Just simple 4 walls to create a box. This will be done through the box tool and you will drag and create the boxes accordingly. This is very important as this step will layout the entirety of the house.
Step 2: Doors
Next, you will create the doors of the house. There will be 2 doors in this house. One in front of the house an done on the back to exit from. You will use the box tool to create these doors and then you will also use the cylinder tool to create the rotation for the door. Once you create the box and cylinder for the doors, you will need to link the cylinder and box together. You will link them together and exemplify that this step is very important because this will create the door part of the house and also the rotation of the door.
Step 3: The Floor
Next, you will create the floor with the box tool. You will place the floor under the walls that you created for the walls surrounding the house. This is very important as this sets the foundation of the house.
Step 4: Inside Walls for Rooms
Next, you will create the rooms for this house. In order to this, you will need to create the sections in the house. This means that you will need to make the 5 rooms needed for this project by creating the walls to surround the rooms. This will be done by using the box tool and creating a wall for these rooms. This is an important step as this will create the sections in the house designating which is room is what.
Step 5: Table for Dining Room
Now you will start to create the dining room for your house. In this step you will want to create the table for this room. In order to make this table you will need to use the box tool to create a box and then you will edit mesh this. You will then use the vertex to create the legs. You will click and drag on the vertex down in order to make the legs. This will create the whole table and this is a very important step for this project because this is adding just one of the components of the entire house.
Step 6: Chairs, Silverware, and Plates
Now you will create the items on top of the table and around them. You will first need to make the chairs. In order to make them, you will need to create a box and then extrude one side of the box to create the backrest of the chair. After this, you will need to create the silverware and plates. The silverware must be created using edit mesh and more boxes again. You will drag and remove vertex's in order to create the silverware. After this, you will need to create the plates and bowls. You will need to create cylinders using the cylinder tool. You will then use edit mesh to create the dip in the bowl and plates. This is a important step in this project because this will add the little details that make this project great!
Step 7: Living Room Couch
Now you will create the couch in the living room. In order to do this, you will need to create a box and use the vertex's of the box to create the little details of the couch. In my couch I decided to do something different and put a dip in the middle of it. This is a important step as you are now starting to create the items in the living room.
Step 8: Living Room Chair
Now you will create a chair in the living room. You can do this easily by cloning the chair you had made in the dining room. Right click on the chair in the dining room and click clone. Then you must drag and place the chair in your desired spot in the living room. This is an important step as this is adding on detail to the living room.
Step 9: Living Room TV
Now you will create the tv for the living room. In order to do this, you will need to create the stand on which the tv will sit on. You will need to create a box and extrude a vertex in the middle of the box in order to make a little stick that will hole the tv up. Then you will create another box that will create the tv and you will place that on top of the stick that you made. This is an important step because this is adding more detail to the living room.
Step 10: Bathroom Towel Rack
Next, you will move onto the bathroom. You will need to create the towel rack for this room. You will need to create a box and then extrude out the box in order to make the rack. This is an important step for this project as you are now starting to add details in the bathroom.
Step 11: Bath/Shower for Bathroom
Now you will need to create the shower and bath for the bathroom. This is essentially a large bowl. You will need to create a bowl and then use the vertex to stretch and create the bath. This is important as this is adding detail to the bathroom.
Step 12: Toilet and Sink for Bathroom
Now you will create the toilet and sink for the bathroom. The sink is another bowl that you will create as you did before. The toilet was a very big struggle for me to create. So you can create the toilet as you desire, but this step is very important for the project as you are now finishing up the bathroom room.
Step 13: Fridge for Kitchen
Now you will create the fridge for the kitchen. This will be done by creating a box and then extruding parts of the box out to create the handles of the fridge. This is an important step of the project as you are now starting to create details for the kitchen.
Step 14: Oven for Kitchen
Now you will create the oven for the kitchen. This will be done by creating a box and then extruding part of the box through edit mesh. This is an important step for this project as you are adding details to the kitchen.
Step 15: Cabinets for Kitchen
Now you will create the cabinets for the kitchen. In order to do this, you will need to create a box and then extrude out the handles for the cabinets. This will be done through edit mesh. This is also an important step as this is also adding more detail to the kitchen.
Step 16: Island for Kitchen
Now you will create the island for the kitchen. This is a very easy step for this room. You will just create a box and select soft selection in the edit mesh settings. This will create a smooth box creating the island for this kitchen. This is an important step for this project because now you are done with the kitchen!
Step 17: Bed for Bedroom
Now you are onto your last room of the house which is the bedroom. In order to create the bed you would need to make a box using the box tool and the extruding part of the bed to create the headrest on the back side of the bed. This is an important step for the project as now you are starting to add details to the bedroom.
Step 18: Dresser for Bedroom
Now you will move onto creating the dresser for the bedroom. In order to do this, you would need to create a box using the box tool and then going into edit mesh to create the little details of a dresser. This step is important as you are adding detail to the bedroom now.
Step 19: Closet for Bedroom
Now you will move onto the closet for the bedroom. In order to do this, you would need to create a box and then use the sphere tool to create little spheres as the handles for the closet. This is an important step for the project as you are now done with creating the whole house!
