Introduction: 3D Modular Wine Rack
Build your own wine rack!
Simple to make (3D printed)
Simple to build (easy modular system)
Please click on the Vote button on the top right corner if you like this project :)
Step 1: Frame
Just print a pair of modules for each bottle.
I will add some different edits/designs once in a while.
(Please note that the pins require support material. Although I'm new at this, I will try to add the support myself and update the .stl file soon.)
Step 2: Base
Use a base for extra stability.
I've added some simple shapes for you to choose from.
If you have 2 modules next to each other at the bottom, use a double pin base.
(There is a 0.2 mm difference in radius between the pin and the pinhole to ensure proper fit)
Step 3: You Decide What Your Product Will Look Like!
Experiment with different structures.
Mix and match frame material and colour.
Change the frame and base design to your liking.
(I also suggest measuring your bottles for best result.)
I'll print some samples in the coming weeks to give you an idea of what it looks like in real life.
(Please note that this is a work in progress so I would not recommend printing a full scale model until after I have released my test/sample results.)
Step 4: Version 2.0
Changes:
- Increased the size of the frame (from 1cm*1cm to 1.5cm*1.5cm)
- Changed the shape of the pins to withstand vertical forces
- Increased the diameter of the pins slightly
- Slightly changed the geometry of the base parts
Hope you like it.
N.B. Make sure to apply a high percentage of infill, especially at the pins, for extra stability.
