Introduction: 3D Print Face Mask
The purpose of this face mask is to help filter out unwanted airborne pathogens. It is easy to do for anyone who has access to a 3d printer, a headband (or some kind of elastic strap), super glue, weatherstripping (can be found at local hardware stores), and an old cotton t-shirt.
The supplies you will need for this project include:
- Access to a 3D printer
- Roughly one foot of weather stripping
- Superglue
- An elastic head band
- Old cotton t-shirt (30 cm in diameter disc)
Tools necessary to complete this project include:
- Drill with a 1/8" to 1/4" drill bit
- Scissors
- Metal file or sandpaper
Step 1: Print Out .stl Files
To begin this project you will need to use the 3D printing software you have available to begin slicing the attached files and then begin the printing process
Step 2: Prepare Printed Parts
Once all of your parts have completed printing you will need to follow these steps to begin assembly
- Remove all supports using your metal file
- Check tolerances on the filter disc when inserted into the secondary housing unit
- Also check the tolerance on the cap and the grooves located in the main housing
- If the tolerances are not accepting of each other, begin to file down to size until the disc and cap slide in and out of their clearances with ease
Step 3: Gluing the Main Housing
- Take the main housing component and hold in place in the hole of the mask to the point where about 2-3 millimetres of the housing unit are protruding from the inside of the mask
- Begin to apply super glue around the edge of the main housing, bonding the mask and the main housing
- Let dry for at least 24 hours
Step 4: Applying Headband
- Using your scissors, cut the headband in half
- Use your drill to drill two holes in the spots indicated by the red dots in the picture above
- Run one end of your head band through the front of one of your new holes
- tie a knot in the end of the head band so that when you pull it the headband is unable to be pulled back through the hole
- Repeat steps 3 and 4 with the other end of the headband and the other hole
Step 5: Applying Weather Stripping
- Cut your weather stripping to about one foot in length using your scissors
- Remove the plastic protecting the adhesive
- Apply the weatherstripping around the outer edge of the mask making sure to press firmly to completely utilize adhesive
- Adjust positioning as necessary for most comfortable fit
- Cut off any excess weather stripping
Step 6: Final Assembly
- Retrieve all of your components
- Begin by placing your 30 cm in diameter disc of 100% cotton t-shirt into the secondary housing
- Place your filter disc into the secondary housing
- Place your secondary housing into the main housing
- Place your cap into the main housing and slide notch into groove to achieve a proper lock
- Apply face mask onto face
