3D Print Light Switch Covers
Intro: 3D Print Light Switch Covers
I've been working on making fancy light switch covers, but really, to do that you first need to understand the design of a basic light switch cover. Here I will share how I designed them as well as the files for Single, Double, and Triple toggle switches in Standard, Mid, and Jumbo sizes!
STEP 1: Design - Size Front
I designed these to print simply in 1 piece with no support.
To start, you need the overall dimensions of the plate. Now you can go around measuring them or make it easy on yourself and look up what the standard sizes are. I found them on Home Depot and used the ones for Single, Double, and Triple toggle switches as that is what I mostly have in my house. To make this easy, I'll talk about designing a Single Toggle Mid sized plate.
My plate will be 3.13" wide by 4.88" tall. I decided to make the front 4mm thick.
As you probably have noticed, light switch covers have edges that are sort of filleted and chamfered. I decided to keep it simple with a 45 degree angle cut on the side so that it would print well upside down.
I mostly eyeballed it and lined it up the best I could on each side. Then, once I grouped it, I double checked the dimensions to make sure I didn't cut too much off.
Now you have the front and we can move to the back.
STEP 2: Design - Back
I decided to make the back also 4mm thick, but you can do a bit less if you want.
This was pretty easy. I did a rectangle in the same dimensions as the front but cut out the center with a pyramid so that it would be wider on the side that touches the plate, and narrower as it went away. Similar to how a light switch cover looks.
STEP 3: Design - Switch and Screw Holes
Lastly, you need the switch design.
This caused me the most grief with many tests. The first part is easy. Measure the toggle opening and the opening for the screw which is smaller in the back of the switch and flares out in the front.
The toggle cutout was a simple cube and the screw holes were created with cylinders and a paraboloid where the screw insets.
Get it all lined up PERFECTLY, and then center it on the plate and group it.
This will be printed upside down.
Something to keep in mind, is if you are doing double or triple, you also have to get the spacing right between these cutouts.
STEP 4: Slicing and Printing
I found using normal settings works fine for this, but you can play around with the surface design by changing the Bottom Surface Pattern since that will actually be the front after it's printed. I tried out regular Monotonic, Hilbert Curve, Concentric (actually did this one on accident, turned out okay tho), Octagram Spiral (looks like a star!), and Archimedean Chord which makes a spiral coming out from the center.
STEP 5: Finished
Enjoy your finished light switch cover!
WARNING: PLA, as far as I know, isn't an approved material to use to make a light switch cover so you use it at your own risk. Also, changing out your cover has the risk of electric shock. Changing out a switch plate/cover can be dangerous, turn off power to the switch before removing and replacing the cover.
7 Comments
dsmith267 20 days ago
Thank you for providing the files! I've been meaning to design these for my shop and now you've saved me that time.
Penolopy Bulnick 19 days ago
Thanks! Glad I could help :)
leethayer8 22 days ago
Nicely done 😀
Thank you :)
jessyratfink 23 days ago
Love the ones with star sparkles! Really pretty :)
Thanks! The sparkling is the best :D
wjcarpenter 20 days ago
You might be interested in this different approach using OpenSCAD: Wally https://www.thingiverse.com/thing:47956. It's useful for making different combinations and numbers of positions. (I don't have any connection with this other than having used it to make a couple of covers; for example, https://www.thingiverse.com/make:1151155)
