Introduction: 3D Printable Perpetual Desktop Wooden Calendar With Watch
In almost every home around the world, we can find calendars we buy every year. We buy calendars with dog, cat, pandas, flowers, etc. What you think to make your calendar?
We wanna introduce our newest project Perpetual Desktop Wooden Calendar with Watch which can look great whatever you want to place it, also the calendar has a quartz watch.
We needed few things to make the calendar. Below you find a list of what we used (with links) to print our project.
Project .stl files - https://cults3d.com/en/3d-model/home/perpetual-desktop-wooden-calendar-with-watch
Printing Model using FDM Printer:
3D Printer Qidi X-Max -https://s.click.aliexpress.com/e/_APV5m1
Wood PLA Filament -https://s.click.aliexpress.com/e/_A3jTwN
Items required to assembly:
Watch DIY -https://www.amazon.co.uk/gp/product/B01D129UF4/ or
https://www.amazon.co.uk/FRIUSATE-Movement-Silent-Replacement-Mechanism/
Is just sample you can buy which you want. On amazon is a lot this.
Post-Processing print:
Nail Files or Sandpaper
Wood Stain - https://www.amazon.co.uk/Furniture-Clinic-Wood-Stain-500ml/dp/B08CXRY1ZY/
Two colour Teak and Rosewood
Kitchen Sponge
Brushes - One bigger to paint holes with stain and second detailed brush size 0 to paint letters and numbers
Metallic Acrylic Paint - https://www.amazon.co.uk/perfect-ideaz-metallic-different-creative/dp/B07GH2JK43/
Step 1: 3D Printing Setting
Like we know every 3D printer is different we will share our settings but it doesn’t mean our setting will work better than yours.
Printer: Qidi X-MAX
Filament: Sunlu Wood PLA
Slicer: Cura
Retraction Distance: 3mm
Retraction Speed: 30mm/s
Layer Height: 0.3mm
Wall Line Count: 3
Top Layers: 3
Bottom Layers: 2
Print Thin Wall: Yes
Infill Density: 10% - 20%
Infill Pattern - Gyroid
Z Seam Alignment: Sharpest Corner
Seam Corner Preference: None
Print Speed: 40mm/s
Minimum Layer Time: 20s
Printing Temp: 195 C
Build Plate Temp: 50 C
Support: Support FREE
Printing Time: Around 1d 12h
Material usage: Around 517g
Step 2: Sanding
After 1.5 days we have it. Printed calendar now time for post-processing. Why we love the print with Wood PLA. We don't have a lot of work with post-processing our model. Maybe just a little bit strings, just use Sandpaper or even nails files from our printer 95% of models come straight to painting.
Step 3: Staining Model
After sanding the model, we are ready for staining our calendar. First, we will paint our base we used the colour Rosewood from our test best to paint is using a kitchen sponge. We apply three layers of stain. Just get a little bit on a sponge and paint base in one way In holes we used brush to paint.
Every layer just leaves little time to dry.
Next, We get the part with letters and numbers which will be inside of the base. Start apply three layers of stain just this time we used the colour Teak. It will take a little bit of time to paint all of it. Leave model to dry for 24h. Time for the next step.
Step 4: Painting Letters and Numbers
Ok, after 24h of waiting we are ready to paint letters and numbers. To this we used Metallic Acrylic Paint colour Gold and brush size 0 we love our brushes to detailed painting. It is the longest process in this project we have a lot of letters and numbers to paint, also there printed two marks which we will paint in gold. We need to apply again 2-3 layers of gold paint to obtain beautiful gold letters and numbers. Is just good because before you finish all previous one should be dry and can be painted straight away.
Step 5: Install Watch Inside Calendar
The last step is to install a watch mechanism inside the calendar. Simply place mechanism inside should fit perfectly. The mechanism place has 56.4mm x 56.4mm. Later assembly watch (add shafts) insert battery and close (optional) form back.
Step 6: WE ARE READY!
Hurray, We finish from now our Perpetual Wooden Calendar with Watch will decorate our living room. We hope you will also have a lot of fun creating this calendar. Please follow us for more instrutables. Visit our store for more great ideas which you can print at home for home. Thank you for your time and see you soon. :)
