Introduction: 3D Printed Braiding Machine / How It Works, Construction, Technical Details
About: As a child, I grew up with Lego technic, model trains, computers and steam engines. As a young adult I started working in a small metal workshop in Austria. There I learned the knowledge of metalworking. When …
In this video I build a 3D printed braiding machine. The braiding machine was recreated from old photos, from the early days of braiding machines. The braiding machine works really great. So far I have created about 50m of cord without any problems. The output is 42cm per minute. A 24V DC gear motor drives the machine. 6 bobbin holders are used. A bit tricky was the device for tensioning the single cords. But this works perfectly now. If you change the gear ratio, it is also possible to produce cords with a core. All parts are easy to print. Supports are included in the 3D models. On Thingiverse and Prusarprinters I have made all parts, drawings and templates available for download. Have fun building.
Youtube: https://www.youtube.com/watch?v=xj4MgT5iLL0&list=PL9Jzxu1vDldMNZdv_c5Pis4F-nQ77MFtc
Thingiverse: https://www.thingiverse.com/fraens/designs
Prusarprinters: https://www.printables.com/de/social/183722-fraens/about
Step 1:
Here you can see the basic assemblies.
Step 2:
The base plate was made of acrylic glass. The shape was printed on paper and glued. The parts are cut, sanded and drilled.
Step 3:
3D print the parts. All parts can be downloaded.
Step 4:
Here you can see the base plate with the gears. 6001-2RS ball bearings are used.
Step 5:
The shuttle is guided in the acrylic guide. The gears push the boat further and further.
Step 6:
This is the coil holder. A 12x1mm aluminum tube was used. The steel weights ensure the maintenance of tension in the cord. The spool holders circle each other, braiding the line.
Step 7:
The extraction speed is set via the gear ratio.
Step 8:
Be careful when threading the cord!
Step 9:
The rope production can start.
You can see more technical details in the video.
