Introduction: 3D Printed DIY AC Power Grommet
It would be quite useful to have one or two power sockets on the table to charge devices something like a laptop or smartphones.
This project doesn't require much support from different tools. In terms of tools 2 things are mandatory:
- 3D Printer
- Phillips Head Screw Driver
Requirement For This Project:
- 1 X AC Socket
- 3 X 0.5sqmm 1.5 Meters Wires (I am preferring Red, Black & Blue)
Step 1: Watch the Video First
Everything is explained in the video below. First of all, Watch it carefully.
Step 2: Take the Measurement of the Table Cutout
First of all, you have to measure the cutout of the table where the AC Power Grommet will enter. This measurement is important. in my design I am not adding any nuts on the back to hold the grommet in place. So, I have to make this grommet as much tight as possible because while removing the plug from the grommet I don’t want that the power grommet also removes from the table.
Step 3: Disassemble a Plug Socket
Obviously the the main component of this project is the socket. After disassembling the back of it we get three individual pins where the plugs actually make contact. These 3 pins and this outer shell are important for my project.
Step 4: Design
To keep all of the measurements in mind I have designed my own desk power grommet in Fusion 360. It also has a lid on the back for safety. Also, we have to carefully measure the dimension of each pin of a 6A D-type plug and their in-between distances which are more or less something like 12.73mm.
Step 5: Print Settings
After exporting the model into the slicer I need to change 5 major settings. Layer height which should be 0.25mm, print pattern Gyroid, temperature: for the nozzle and bed 220 degrees Celsius and 60 degrees respectively, Print speed: 120mm/s would be enough, and finally Infill density which represents the strength of the print - I choose 55% infill. That’s it. Let’s slice it and move the GCode to the printer. By the way, I have used PLA to print all the parts.
Step 6: Additional Parts
Also need two spacers. Watch the video to understand why.
Step 7: Assembling the Power Grommet
Now, it’s time for Assembling, first of all, I have inserted the spacers on top of the unnecessary holes and used a bit of two-component adhesive on them.
Next, I have placed the pins on their respective cutouts and put the socket’s back cover in place. That’s possible because in design I have left grooves so that the piece can easily slide into.
As with the design, I have left a screw hole on the body so that I can easily use a screw to mount the socket on the back – not too tight not too loose.
Step 8: Download All the Files
All the project files...
Step 9: Wire the Extention Cables
While that is done I have prepared the extension wires. I have picked 0.5sqmm red, black and blue respectively for phase neutral and earth. I need 1.5 meter of them. After stripping them off I have hooked them up accordingly. The right side from the front is phase so from the back left side is the phase, the right side is neutral and the thick one is for earth.
Next, what’s mandatory is to connect a suitable plug top. This is the wiring scheme that I am going to follow. Right side is phase left is neutral and this big one is for earth. The wiring is completed.
Step 10: Install the AC Power Grommet on Table
All we have to do is to set it in the desk cutout and the back plate for safety. So, I have passed the plug through the hole and set the grommet with a lot of pressure. Finally, I have set the back cover of the AC power Grommet with super glue.
Step 11: Success: Let's Use
I have charged my laptop with this AC power grommet without any problem.
