Introduction: 3D Printed Generator and How It Works.
In this video I build a 3D printed generator. It is driven by a gear ratio by hand. There are 8 pieces of magnets with a diameter of 15mm. The centric wave has a diameter of 12mm and is ~ 90mm long. For the 6 pieces of copper coils I used a 0.5mm painted copper wire. It is needed ~ 50m wire. The rotor has a diameter of 95mm. All parts were printed from PLA.In the video I used a much too strong lamp. As a result, the efficiency is relatively low. This should actually be slightly higher.
Youtube: https://www.youtube.com/watch?v=hPnHBAiMHJQ&list=PL9Jzxu1vDldMNZdv_c5Pis4F-nQ77MFtc&index=9
Thingiverse: https://www.thingiverse.com/fraens/designs
Prusarprinters: https://www.printables.com/de/social/183722-fraens/models
Step 1:
Here you can see the assemblies.
Step 2:
Print the parts.
You can download all parts.
Step 3:
The coil holders are mounted. These are wound with 0.5mm copper wire and pressed into the stator.
They are fixed by means of adhesive tape.
Step 4:
The magnets must be mounted alternately. The opposing magnets attract each other.
Step 5:
The parts are assembled.
Step 6:
An alternating magnetic field is generated which moves the electrons back and forth. This generates an alternating voltage.
Step 7:
This 3 phase AC voltage must be converted to DC. This is done with a simple circuit. Only 6 diodes are needed.
Step 8:
Performance test in my Emco Compact 5.
Step 9:
The generator can also be driven by means of gears.
For more information check out my video.
