Introduction: 3D Printed Holo Clock With Arduino
Hello everyone! This is my first instructable.
This project is a 3D printed clock powered by a stepper motor and is controlled by an Arduino Uno. It was designed in OnShape over the course of a month. It keeps time as precisely as the stepper motor I used will allow and only needs to be plugged into a USB port once programmed.
Credit to ekaggrat for the design idea. See their project here
There may be missing files or errors. If you spot any, let me know.
Arduino Uno
28BJY-48 stepper motor
ULN2003 stepper motor driver
6 male to female jumper wires
A 3D printer
2 different colors of filament (I used black and white PLA+)
2 M4 nuts
2 M4 screws 6mm long
4 M3 screws 10mm long
8 M3 washers
Masking tape
Super glue
M4 and M3 allen wrenches
3.18mm x .335mm brass tube (see below)
Link for the brass tube: https://www.amazon.com/PRECISION-METALS-8127-RND-Tube/dp/B000BQOPWM/ref=sr_1_4?dchild=1&keywords=precision+metals+1%2F8+x+.014+brass+tube&qid=1626543332&sr=8-4
Note: I only used such a strange tube because it was all I had on hand.
Step 1: Print the Parts
All parts should be printed at .2mm layer hight.
For the gears: All of them should be printed in black.
For the other parts: All of them should be printed in white, and only minutes ring and hours ring need support.
The images show where support is required on the parts.
Frame C should be printed twice.
28BYJ-48 10t.stl
12t #2.stl
12t.stl
30t-10t.stl
30t-24t.stl
40t-10t.stl
50t.stl
12t-60t.stl
brass tube cap x10.stl
frame a.stl
frame b.stl
frame c.stl
hours ring.stl
inner frame a.stl
inner frame b.stl
inner frame c.stl
minutes ring.stl
roller x7.stl
arduino uno case lid.stl
arduino uno case.stl
uln2003apg driver case.stl
uln2003apg driver case lid.stl
roller shaft x6.stl
large roller.stl
Step 2: Cut the Brass Tubes
To cut the tubes, put the brass tube into the vise and cut it with a dremel.
The lengths of the tubes are:
45mm (make 3)
34mm (make 1)
25mm (make 2)
20mm (make 1)
Note: These are not the actual lengths of the tubes, but rather longer versions that will be sanded down later.
The video below shows how I cut the tubes using my Dremel 200.
Step 3: Sanding the Tubes
All of the tubes from the previous step should be sanded to the lengths below.
The 45mm tubes should be sanded to 41mm.
The 34mm tube should be sanded to 29.4mm.
The 25mm tubes should be sanded to 22.7mm.
The 20mm tube should be sanded to 17.7mm.
All of this should be done in a vise and with a dremel.
Step 4: Framework Assembly Pt. 1
Glue the roller and roller shaft together and place it in one of the 3 holes on frame A with an arrow pointing to it and glue it in the hole. Repeat this 2 more times. Repeat this on frame B.
Step 5: Framework Assembly Pt. 2
Using the pictures above as a guide, install the stepper motor into frame A using 2 M4 nuts and screws. After the motor is installed, take a small amount of masking tape and wrap it around the shaft of the stepper motor once. This will ensure that the shaft of the stepper motor will hold its gear tightly.
Step 6: Framework Assembly Pt. 3
Inner frames A, B, and C can all be glued to the framework using the method depicted in the first 2 pictures. To put the inner frames on, you should use one of the brass tubes to stabilize the frame when you glue it on to one of the main frames. The last picture shows where each of the inner frames should be once they are glued on. Frame A is on the right and frame B is on the left.
Step 7: Framework Assembly Pt. 4
Glue both frame C parts into the indents in frame A.
Step 8: Gears Assembly
The photo above shows the tubes and the gears. Each gear is labeled. Directly above or below each shaft is its length. Next to each end of the shaft is the length of the amount of shaft protruding from the gear. Once you position the shaft, glue it in place. Repeat this for each gear.
Step 9: Adding the Gears
The pictures above show the order in which to add the gears. It also shows the assembly of 60t-10t with a roller and a large roller. Use the last pictures as a reference to see where the gears and washers should go.
IMPORTANT: Remember to put the minutes ring with frame A and the hours ring with frame B. Also remember to set the clock to 12:00 when you assemble it.
Step 10: Adding the Caps
On each side of the clock there are 5 exposed brass tube ends. Glue a cap to each of the exposed ends.
Step 11: Adding the Circuits
Screw the Adruino Uno in to its case using two screws. Do the same with the ULN2003 stepper motor driver.
There are several photos showing the positions of the wires on the board. Remember to connect the stepper motor to its driver.
Step 12: Arduino Code
Download the code below and and upload it to the board. Make sure the motor is rotating.
Step 13: Conclusion
I really hope you enjoyed this project as much as I did.
If you have a questions, comments, or tips, please let me know.
I look forward to making more instructables in the future.
Below is a time-lapse of the clock running for fifteen minutes.
