Introduction: 3D Printed House From Revit
This is a one story home with a basement, designed in Revit, these steps will also work with a project with 2 or more stories. This Project will allow for the different stories of your design, including your roof, to nest nicely together instead of sitting loosely on top of eachother.
Once I exported these files as STL files, I printed the individual sections on a Stratasys F170 Printer using ABS filament. The purpose of this project is to allow you to see inside your house, through doors and windows, as well as from the top down.
Step 1: THE ROOF (info)
In this section, you will prepare the roof for 3D printing. This will include drawing walls attached to the roof which will act like a ledge to nest it into the first floor.
Step 2: Roof Instructions
Reference Images in Order
  1. Open Revit Project
  2. Select your First Floor from the Project Browser
  3. Select one Dimension, a Window Tag, and a Door Tag -> Right Click -> Hide in View -> Category
  4. You are making the view less cluttered to work in
  5. From the Ribbon, select the wall tool: Architecture -> Build -> Wall: Architectural
  6. Select 8" Generic from the Type Selector
  7. Reference image 1
  8. Change the Offset to 1", Join Status to Disallow and the Top Restraint to Roof
  9. Reference image 2
  10. Draw walls in the following locations, ensure all new walls are offset from the exterior walls on all sides (1")
  11. Reference image 3
  12. Ensure the new walls don't connect to your pre-existing walls in any way
  13. Switch the the 3D View from the Project Browser
  14. Select your exterior walls using Ctrl, right click, select Hide in View, Element
  15. Reference image 4
  16. Select the new walls using Ctrl, select Attach Top/Base, then click the Roof
  17. Reference image 5
  18. From the Properties Palette, change the Base Offsetof your new walls to 8'
  19. Reference image 6
  20. In the 3D View, select everything except for the new walls and your roof -> Right Click -> Hide in View -> Elements
  21. Reference image 7
  22. Ensure you also hide your ceiling
  23. Select one of the walls that follows the slope of the roof and select Edit Profile
  24. Reference image 8
  25. Adjust the profile of the walls using the Drawcommands in the Modify tab, and the other sloping walls so they look like image 9
  26. Click the green Finish Edit checkmark when you are done with each wall
  27. At this point your roof should look like image 10
  28. Export as an STL File
  29. Reference image 10
Step 3: First Floor
DURING THIS PROCESS I USED TEMPORARY HIDE/ISOLATE, THERE IS A BLUE RIBBON AT THE TOP OF MY SCREEN, DISREGARD THIS AND FOLLOW THE STEPS LISTED
  1. Reset your hidden elements
  2. Reference image 1
  3. Select the Roof and the Basement-> Right Click -> Hide in View -> Element
  4. LEAVE YOUR STAIRS FOR NOW
  5. Reference image 2
  6. Select One Window and One Door -> Right Click -> Hide in View -> Category
  7. Reference image 3
  8. Select the Ledge Walls which were used in the roof 3D print -> Right Click -> Hide in View -> Element
  9. Reference image 4
  10. Open the BasementPlan from the Project Browser
  11. From the Ribbon, select the wall tool: Architecture -> Build -> Wall: Architectural
  12. Select 8" Generic from the Type Selector
  13. Change the Offset to 1", Join Status: Disallow, Top Constraint: First Floor and draw walls around the interior perimeter of your basement
  14. Reference image 5
  15. Switch back to the 3D View from the Project Browser
  16. Select all your new walls using Ctrl
  17. Click Attach Top/Base, then click the First Floor
  18. Reference image 6
  19. Change the Base Offset of your walls to 6' 6"
  20. Reference image 7
  21. Look from the Top at your stairs, adjust the Floor Profile and the Walls to make a 1" gap between the edges of your stairs and your floor
  22. Reference image 8
  23. Select your stairs -> Right Click -> Hide in View -> Element
  24. Export as an STL File
  25. Reference image 9
Step 4: Basement
  1. Reset your hidden elements using the lightbulb on the bottom left bar
  3. Drag your mouse to select everything except for the basement and the stairs ->Right Click -> Hide in View
  4. Reference image 2
  5. Open your Basement plan from the Project Browser
  6. Select the Wall command: Architecture -> Build -> Wall: Architectural
  7. Change the Finish Face to Finish Face: Exterior, and draw walls around the inside of the staircase starting at the indicated point, and going clockwise on the same sides as Image 3
  8. Open the 3D View from the Project Browser
  9. Turn on a Section Box from the Properties Palette, and adjust the North, South, and East sides to match Image 4
  10. Double Click to edit the profile of the new walls so that they follow the Middle of the staircase
  11. the North and South walls should be triangles
  12. Reference image 5
  13. Make sure nothing is selected, and turn off the Section Box
  14. Export as an STL File
  15. Reference image 6
