Introduction: Easy Paper Plane Launcher
This is a paper plane launcher that flies really far. It has a 3D printed hook that connects to a paper plane so you can launch it using a rubber band.
You will need. . .
- 3D printer (or go to a local maker-space)
- Tinkercad (optional)
- Regular rubber band (about 2 inches long)
- Size A4 printer paper
- Large paper binder
Step 1: Fold the Plane
In order to launch a plane, you have to have a plane.
A: Get a regular A4 piece of paper. (Most printer paper.)
B: Fold the paper in half and then unfold it again.
C: Fold the top edge to the left edge and unfold it.
D: Fold the top edge to the right edge and unfold it. Now you have a cross.
E: Fold the right edge to the line you just made.
F: Fold the Left edge to the other line of the cross.
G: Fold the top down so the lines from the cross match up.
H: Fold along the lines so the plane has a point.
I: Fold the little tap up over the folds you just made.
J: Fold it in half so the folds are on the outside.
K: Fold the wings to a point
L: Make sure the edge of the wings line up with the back point of the plane.
M: It should look like the picture.
N: Lastly, pinch little taps on the back of each wing. This will make it fly upward at and angle so it won't nose-dive into the ground.
Step 2: Design the Parts
Using Tinkercad, I designed the hook. A full Instructable will be coming out on how I made it.
It took many tries and lot's of effort.
If your making your own launcher, there at least has to be a hook for the plane, a place for the rubber band, and a place for the plane to hook onto.
Step 3: 3D Print the Parts
Print the part.
Step 4: Hook Onto Plane
Slide the hook under the tab of the plane. It should fit perfectly and when you pull it forwards it should not fall out.
Add a piece of tape on the plane so the tab stays on the back of the plane. This is so when you pull back, the plane won't rip.
Step 5: Make Launcher
To make the launcher, cut the rubber band on one side and tie them onto each end of the paper binder.
Step 6: Make It Fly
Now all you have to do is place the plane hook onto the end of the rubber band.
Pull back, let go, and watch it fly!
