Introduction: 3D Printed Racecar With DIY Wheels
 This design allows children to be distracted and have fun playing or making it. I embarked on this project because I wanted to do something simple that others could do as well; in order to do this I used Fusion 360 to make my design then 3D printed it. However one can not print the wheels of the car and this was found out due to the car not moving at all with the wheels when I 3D printed it.
The body of the car has two small holes where the wheels should be, so that the wheels can be connected with a skewer going through the hole, which then allows the car to move. Yet with that the car does not run smoothly so rubber bands should be hot glued to the back wheels in order for the car to move smoothly.
There were a few different approaches to make the care move, but I wanted to do something simple that others could do easily. It also lasts longer because it doesn't need batteries or anything; all that it needs is for someone to move it. It’s like a toy car that somebody can play with or just move when they're bored. This design can allow kids to learn and have fun like I did doing this design, since building it and designing it was fun to do.
  1. 3D Printer: Get the body of the car printed
  2. Red and grey color paint: For the car to have more color
  3. Water bottle caps: Let the car be able to move
  4. Skewers: Connect the wheels together
  5. Thick rubber band: Allows the car to run smoothly
  6. Autodesk Fusion 360: Create the design of the car to print
  7. Flash Drive: Able to print and save design more easily
  8. Needle: to make hole in water bottle cap
  9. Scissors: Cut rubber bands
  10. Lap top
  11. Fusion 360: an app
  12. Flash Print: an app
Step 1: Creating Design
Step 1: Create design of Race Car in Autodesk Fusion 360, but once done extrude the wheels inward creating a hole between the wheels, then instead of saving export to your desktop
Step 2: Materials
Gather all supplies you’ll need in order to start creating the design
Step 3: Download Flashprint
If you do not have the app Flashprint on your desktop then download it.
Step 4: Exporting
Then export the 3D design as a STL file
Step 5: Preparing to Print
 After Download the file into the FlashPrint 5 app and choose the type of machine you would like to print on, and choose how detailed you would like the design to be printed.
Step 6: Printing
Press print and just wait for how long it’ll take to print
Step 7: Creating the Wheels
Grab a skewer and cut 2 inches off do this twice then create a hole in the middle of the water bottle cap using a needle, do that to all 4 water bottle caps
Step 8: Connecting the Wheels
Grab your water bottle caps and the 2 inch skewers then put it through the hole through the print then grab two water bottle caps connected then repeat for the other one. Once both set of wheels are connected hot glue to skewers to the cap to ensure that it does not move at all.
Step 9: Enhancing the Wheels
Grab the thick rubber band, and see how much the wheels is going to use, then began to hot glue the rubber band around the wheel, repeat for all the wheels
Step 10: Painting
Paint the front and back flaps red then paint the wheels grey and let dry
Step 11: Enjoy!
Well done! I hope that this project was fun for you all!
