Introduction: 3D Printed Spot Light Shelf
Quirky 3D printed lamp with a shelf to highlight a special trinket. It won't provide much support, so whatever is stored on the shelf can't be too heavy.
Step 1: What You'll Need
3D printed parts
filler, paints and varnish- if you want to process your prints, if not, just print the parts in different colours
gorilla glue for plastics
1-2 12V LED strips
two wires or a repurposed cable (I used a cable from an old usb cable)
soldering iron
female connector https://www.amazon.co.uk/EFISH-Connector-Terminal-...
12V AC/DC converter
Step 2: Clean Your Parts
I used a filler and sanding paper to get all parts, lampshade in particular, as smooth as possible.
This is optional of course, if you prefer to use raw prints, just print the shelf using yellow filament and lampshade in different colour.
Step 3: Joint Both Parts
Mix small amount of gorilla glue and glue both parts together. Leave it to dry on a flat surface.
If you are going to paint it later, use a small amount of filler to cover the joining, smooth it with sanding paper.
Step 4: Painting
Paint with acrylic paint, enamel paint of spray paint. Varnish if necessary.
Step 5: LED Strips
Thread a cable through the hole at the top of the lampshade and then thread it through the small half-moon part.
Glue the LED strips to the half-moon part and solder everything.
Use glue to secure the half-moon with LED on the inside.
Step 6:
Drill two parallel holes, 5.5cm apart, attach wall hooks or screws and hang the lamp.
