Introduction: 3D Printed DIY Wall Clock
In this project, we will create a unique 3D-printed wall clock. The clock features individual rectangular strips for each digit and a center plate to house the gearbox. This guide will take you through modeling, printing, assembling, and installing your custom wall clock.
- Clock module with clock hands (hour, minute, second)
- Stencil paper (2D file provided)
- Double-sided tape (1inch width)
- Paper Tape (for hanging the stencil)
- Basic tools (scale, cutters, scissors)
- 3D printer
Step 1: Modeling the Parts
I modeled all the parts in Autodesk Fusion 360 needed for this project.
The parts include:
- Short Rectangular Strips: These represent the digits "1, 2, 4, 5, 7, 8, 10, 11."
- Long Rectangular Strips: These represent the digits "12, 3, 6, 9."
- Clock module case: This has a diameter of 9 cm and includes a specific cutout to fit the clock module.
Note- Each part is designed to be easily identifiable and placed on the wall according to the stencil provided.
Step 2: 3D Printing the Parts
Use the STL files given above and print the following parts using a 3D printer:
- 8* Short rectangular strips
- 4* Long rectangular strips
- 1* Clock module case
I used black filament for a sleek and modern look. However, you can use any color that matches your theme or decor.
Step 3: Preparing the Parts
Attach double-sided tape to the back of all the printed parts. Make sure to:
- Cut any extra tape that extends beyond the edges of the parts.
- Ensure the tape is not weak or old for a secure hold.
Step 4: Assembling the Clock Module
- Place the clock module behind the module case inside the specific cutout.
- Secure the module with a bolt from the front, provided with it.
Step 5: Attaching the Hands
Attach the hour, minute, and second hands to the module, ensure they are properly aligned, and move freely.
Step 6: Take a Look!
Now that the assembly is complete, we move on to the installation part where we use a stencil to align the clock symmetrically.
Step 7: Using the Stencil
- Check the size of your stencil paper, use at least (40cm*40cm)
- Use the provided file to create your stencil.
- You can use a laser cutter or plotter or you can do it by hand using a sharp blade.
Tape the stencil to the wall where you want to place the clock, ensuring it is positioned correctly.
Tip- I have done it manually, and I think you should also do it by hand if you don't have these fancy machines, like me!
Step 8: Attaching the Parts
- Tape the stencil to the wall where you want to place the clock, ensuring it is positioned correctly.
- Attach the 3D-printed parts to the wall according to the stencil layout.
- Ensure each part is securely fixed using double-sided tape.
Important Note- Insert the 1.5v AA battery inside the clock module and check it properly, before pasting it to the wall.
Step 9: Finalizing the Clock
Carefully remove the stencil, ensuring all parts remain in place. Check that all parts are securely attached and aligned properly.
Tip- You can also remove the hands of the clock before removing the stencil and attach them later, to make the installation easy.
Step 10: Conclusion
Congratulations! You have successfully created and installed your custom 3D-printed wall clock. Enjoy your new, personalized timepiece!
