Introduction: 3D Printed Watch Case Build
This build is an easy project that adds a little style to your watch collection. This is a simple 2 watch design using simple components and 3D printed parts. The cost is roughly $25 in components and it takes about 17 or so hours to print.
Step 1: What You Will Need
Step 2: 3D Printed Parts
Print time is roughly 17 hours for all 3 pieces @ 60 mm/s. The difficulty I would classify as easy for both the printing and assembly.
Watch Case (decent surface quality to limit amount of sanding needed)
Filament choice not really important
0.2mm layer height25-30% infill (ideally you use multiple processes and use a high infill for at least the first 10mm if you can.
Support is optional depending on overhang performance
Brim optional
Cover and Cover Back Plate
0.2mm or higher layer height15-20% infill
Support recommended
Brim optional
Step 3: Finish 3D Printed Parts
- Remove any support material.
- Sand pieces to the desired smoothness.
- Start with 220 or 320 grit and move up until you have a nice smooth part without visible print lines.
- Wipe the sanded parts with a lightly damp cloth or paper towel.
- Apply even and a light coat of primer.
- Allow enough time for the primer to dry, then sand lightly.
- Once the parts are dry, evenly apply light coat(s) of base coat spray paint.
- At this point, you can either finish with a clear coat or you can hydro-drip your parts (you can see a full guide on how to do that here.)
Step 4: Assembly
- Prepare acrylic by cutting to a 3.6” x 4.3” rectangle. I used painters tape, marked the lines, and then cut using a jigsaw.
- Slide acrylic rectangle into the back of the cover.
- Slide (glue optional) back cover plate behind the acrylic sheet.
- (For a seamless look, slide acrylic into before finishing the cover and use Bondo Spot Putty to fill the seam and then finish.
- Review how hinges operate and ensure orientation is correct before inserting into all 4 mounting holes.
- Now you are ready to wrap your watches around the watch pillows, insert into the case and close the lid. I hope you enjoy your 3D printed watch case!
Step 5: Wrap Up
Thanks for checking out the Watch Case 3D Printed build! If you enjoyed it, I post monthly builds using 3D printing on my website, https://www.adylinn.com/builds/ .
