Introduction: 3D Printed Willys RC 4X4
This is a remixed version of the original Ossum Jeep. While it is dimensionally exact and shares a few components with the original, this is an entirely different beast that is designed from the ground up to be fully 3D printed, including the axles and entire drivetrain. It is a true 1:10 scale radio controlled, full-time 4X4 Jeep.
This project started after I got in contact with Mr. Ossum inquiring about a fully printed version that did not rely on a donor RC vehicle. After learning that no plans to create such a version existed in the near future, a few ideas were exchanged, a new friendship was made and the urge to design what I had envisioned needed to be fulfilled.
The Jeep uses parts that can be bought online or at the local hobby and hardware store. Links are provided to various items on Amazon and AliExpress. The STL files are available on Thingiverse.
Files: 3D Printed Willys RC 4X4
Please feel free to visit the Limitless RC Group on Facebook if you have any further questions or just want to share your designs. You can also visit the Ossum Group if you'd like. There you can discuss the build of the original Ossum Jeep.
Thanks for your time and enjoy the instructable.
PS. I am doing my best to get this done ASAP. Please be patient and check back for regular updates.
Step 1: Materials, Components and Hardware
The following is a list of all materials and components that were used to build the Jeep. Any deviation from this list is at your own risk. If you find a better solution to something then feel free to post about it on the facebook group.The Jeep is designed to be printed in PETG for its strength characteristics and flexibility. It is also very affordable. Most of the links provided are either to Amazon or Aliexpress. You can also check out your local hobby shop but it is much cheaper to buy online from these retailers.
Materials
1kg PETG Plastic Spools - Color of choice for the body and black for the frame and drivetrain.
3mm Carbon Fiber Tubing T507LA4 - For the steering tie rod and steering column.
6mm Carbon Fiber Tubing T518Lm - This is for the axle shafts and transmission input/output shafts.
Components
Lego Technic Universal Joint, 3 Studs Long - You will need at least 6 of these.
7.4 Volt 260 Size Electric Motor - Tamiya motor must be upgraded to something that can handle 7.4V
Tamiya High Power Gearbox 72003
FlySky GT3B or Spectrum STX2 TX/RX - Only tested with these two.
Bearings - You will need around 22 of these to complete the Jeep.
Lipo Batteries or 2X Lithium-Ion 18650 Cells or Li-Ion Battery Pack for RC
18650 Battery Holder These are optional depending on if you want to use single 18650 Li-Ion Cells instead of LiPo or the Li-Ion Pack.
JST Connector Pairs with 8" leads - Or you may use other connectors + wire. The wire must be at least 20 gauge.
Hardware
1/8" Key Stock (Square Shaft) - 2 X 12"
M4X0.70 Nuts
M2 X 4-16mm Assorted Screws - Select Cap Head
M2 X 10mm Self Tapping Socket Head Screws
M2 X 8mm Self Tapping Socket Head Screws
M2 Threaded Inserts - These are optional depending on if you want to build the roll cage or not.
6mm ID X 12mm OD Steel Washers - Get these from the hardware store.
1.5mm Floral Wire - Get this at a craft store.
Tools
1.5mm Hex Driver or Allen Key.
Bi-Metal Hacksaw Blade
Nail File or 300 Grit Sandpaper
Step 2: Front Axle Assembly
Please follow the instruction text in the photos. These instructions were designed to be presented in a visual format. All efforts were made to ensure accuracy and everything seen here should be repeatable by the end user. If there are any edits or future updates, they will be placed below this text in a written format. Feel free to contact me if you are having any issues with this instructable.
Step 3: Rear Axle Assembly
Step 4: Engine Assembly
Step 5: Drivetrain Assembly
Step 6: Frame and Suspension Assembly
Step 7: Final Assembly
COMING SOON
2 People Made This Project!
- RCA5 made it!
- riccio3486 made it!
25 Comments
Question 1 year ago on Step 1
looks nice. trying to order the stuff I need to build it but some links dont work. could you please update them? tia
Answer 1 year ago
I searched the ones that didn't work up on amazon took a little digging but found the stuff that was needed and the little all bearings you need are size mr106-2rs just in case your wandering about those
5 years ago
I'm working on building one , but the gap between parts is too big .
I have to insert a paper sheet with CA to fix it
Reply 5 years ago
The gap between what parts? You will have to be more specific and give me more detail. I printed two of these Jeeps and others have as well and this is the first time I hear of the problem.
Reply 1 year ago
I am currently working on getting all the pieces printed going to put it together with my sons when they are finished this will be my first rc build ever and i am haveing a great time in doing so and even greater when my sons become part of it as well so lust sending a very big thanks to you for creating this model it will be some time well spent with my children thank you
Reply 5 years ago
for example , you leave bearing holes 10.4mm diameter for a 10mm diameter bearing , but it will be perfect with 10.1-10.15 diameter hole. And a 1.8mm hole for selftapping Screws will be perfect
Reply 5 years ago
Are you printing with petg? Did you get the bearings from the exact source I posted? There are many variables here that could be causing this. I was told on the Facebook group that the holes are on the snug side. The holes are designed this way for petg and to factor in the 0.1mm-0.2mm resolution lines most people get. For me the bearings snap right in when I take the part off the printer. The bearings are 10.1X mm diameter when I checked them with the caliper.
Reply 5 years ago
I am in China, so the parts I buy are definitely not the same source you posted.
It does not matter, I modified a few parts, and now the frame and the transmission have been completed.
Still waiting for your further instructions
Reply 5 years ago
Follow the Ossum Jeep build for the body. It is the same body as this but this uses glue instead of screws. I will be finishing the rest soon.
Reply 5 years ago
jingweil it not his parts it u`r printer is not setup right
Reply 5 years ago
Really? I have printed the original Ossum Jeep , and made so many remix parts fot it , have no such issues
Question 1 year ago on Step 4
Im probly over looking it but can you tell me what size bearings i need to get for this jeep
1 year ago on Introduction
Having a bit of trouble finding some of the parts i need to put this jeep together i am currently printing it and i have seemed to have gotten overly excited about it as well i feel like a kid again who cant wait to get his toy out of the box to play with it
2 years ago on Step 6
Step 7 ?
4 years ago
Currently building mine. Not sure if I'm gonna go the full r/c route yet or just have it as a bad ass display piece :)
Reply 4 years ago
Please, would you tell me what pieces do I need to do this thing, without RC?
4 years ago
Constantly broke. Replaced by metal. Thanks for the great model !! https://www.youtube.com/watch?v=aoxn3kkNyfQ
Question 4 years ago on Introduction
Hey, Do you know the total cost of the project? (including the transmitter)
Also, will it be possible to use Rc plane hardware? (I have some of that stuff laying around)
5 years ago
Im building one, love it.... parts fit fine....the design is good and fairly strong, iv struggled to get a gearbox here in the UK, iv sourced one from France finally, this design has so much potential, ill be altering some of the mechanical parts to a more robust version over time.
Reply 4 years ago
Shes getting there, replaced the chassis (with a black one) ironed out some niggles and had to repair the Tamiya gearbox (note: use PLENTY of grease) the 2 speed gear changer works well too, ordered an upgrade metal gear servo for the steering.
