Introduction: 3D Robotic Arm With Bluetooth Controlled Stepper Motors
In this tutorial we will see how to make a 3D robotic arm, with 28byj-48 stepper motors, a servo motor and 3D printed parts. Printed circuit board, source code, electrical diagram, source code and lots of information are included on my website
Step 1: Application
Download application and source file -> http://rogerbit.com/wprb/wp-content/uploads/2020/07/robot_bluetooth_uln2003.zip
Step 2: Circuit
Step 3: Project Materials
Arduino uno
Characteristics
- Microcontroller: ATmega328
- Operating Voltage: 5v
- Input Voltage (Recommended): 7 - 12 v
- Digital Input / Output Pins: 14 (Of which 6 are PWM outputs)
- Analog Input Pins: 6
- Flash memory: 32 KB (ATmega328) of which 0.5 KB is used by Bootloader.
- SRAM: 2 KB (ATmega328)
- EEPROM: 1 KB (ATmega328)
- Clock Speed: 16 MHZ.
Step 4: Stepper Motor 28BYJ-48
The parameters of this stepper motor are:
- Model: 28BYJ-48 - 5V
- Nominal voltage: 5V (or 12V, value indicated on the rear).
- Number of phases: 4.
- Speed reducer: 1/64
- Step angle: 5,625 ° / 64
- Frequency: 100Hz
- DC resistance: 50Ω ± 7% (25 ° C)
- Traction frequency:> 600Hz
- Non-pull frequency:> 1000Hz
- Traction torque:> 34.3mN.m (120Hz)
- Self-positioning torque:> 34.3mN.m
- Friction torque: 600-1200 gf.cm
- Drag in torque: 300 gf.cm
- Insulation resistance> 10MΩ (500V)
- Electrical insulation: 600VAC / 1mA / 1s
- Insulation degree: A
- Temperature rise: <40K (120Hz)
- Noise: <35dB (120Hz, no load, 10cm)
Step 5: ULN2003APG
Main Specifications:
- 500 mA nominal collector current (single output)
- 50V output (there is a version that supports 100V output)
- Includes output return diodes
- Inputs compatible with TTL and 5-V CMOS logic
Step 6: Features of Servo SG90 Tower Pro
- Dimensions (L x W xH) = 22.0 x 11.5 x 27mm (0.86 x 0.45 x 1.0inch)
- Weight: 9 grams
- Weight with cable and connector: 10.6 grams
- Torque at 4.8 volts: 16.7 oz / in or 1.2 kg / cm
- Operating voltage: 4.0 to 7.2 volts
- Turning speed at 4.8 volts: 0.12 sec / 60º
- Universal connector for most radio control receivers
- Compatible with cards like Arduino and microcontrollers that operate at 5 volts.
Pinout
Orange–> Signal
Red–> Positive
Brown–> Negative
Step 7: HC-05 Bluetooth Module
- Works as a bluetooth master and slave device
- Configurable using AT commands
- Bluetooth V2.0 + EDR
- Operating Frequency: 2.4 GHz ISM Band
- Modulation: GFSK (Gaussian Frequency Shift Keying)
- Transmit Power: <= 4dBm, Class 2
- Sensitivity: <= - 84dBm @ 0.1%
- BERSecurity: Authentication and encryption
- Bluetooth profiles: Bluetooth serial port.
- Distance of up to 10 meters in optimal conditions
- Operating Voltage: 3.6 VDC to 6 VDC
- Current Consumption: 30 mA to 50mA
- Chip: BC417143
- Version or firmware: 3.0-20170609
- Default Baud: 38400
- Baud rates supported: 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200.
- Interface: Serial TTL
- Antenna: Integrated in the PCB
- Security: Authentication and encryption (Default password: 0000 or 1234)
- Working temperature (Max): 75 ° C
- Working temperature (Min): -20 ° C
- Dimensions: 4.4 x 1.6 x 0.7 cm
Step 8: 4 LEDs (optional)
Step 9: Pins (optional)
Step 10: Jumper
Step 11: PCB
Download Gerber file -> http://rogerbit.com/wprb/wp-content/uploads/2020/07/CONTROLADOR-DE-MOTOR-PASO-A-PASO.zip
