Introduction: 3D Trophy
This is a trophy made with Onshape
https://www.onshape.com/en/
Step 1: Sketch Trophy
Make a sketch of the trophy.
Step 2: Revolve Trophy
Use revolve on the top part of sketch 1.
Step 3: Extrude Base
Extrude the other part of sketch 1.
Step 4: Sketch Text
Add text for the front of the trophy.
Step 5: Exdrude Text
Extrude the text
Step 6: Sketch and Extrude Text Frame
Sketch the text frame on the trophy and extrude.
Step 7: Sketch and Revolve Trophy Handles
Sketch and revolve the trophy handles
Step 8: Sketch and Extrude Trophy Lower Base
Sketch and extrude the trophy lower base, they should be different sized SQUARE
Step 9: Sketch Design to Be Loft
Sketch a design to be extrude and loft on the top plane, use section view to see your sketch clearly, I also used the circular pattern tool to make the 5 other profiles.
Step 10: Extrude Design
Extrude design up to part 1, so it will stop when it hits part 1(trophy)
Step 11: Sketch Profiles to Be Lofted
Sketch profile to be loft, I sketched a profile on top of one of the base of the trophy and i also made another profile on a offset plane.
Step 12: Loft
Loft, select the face of extruded part (From Step 10) and sketches(From Step 11) as loft profile.
Six Times.
Step 13: FINISHED
You're done !! (My handle kinda fell off)
