Introduction: 3D Printed Swamp Boat
The boat consists of two parts, which are screwed together.
I took the motor and ESC out of my MHQ hovership, the receiver of my model car and the servo that just lying around.
The boat has an integrated cable duct to "invisible" do all the wirering.
This Boat is also great to use with a FPV setup =)
Step 1: CAD Design
I have designed the swamp boat so all cables can run the hull in a cable duct.
The ESC and the reciever are covert in the front part of the boat.
The Battery is in the rear part to ceep the center of gravity behind the middle.
Step 2: All You Need
- 3D printer
- 4 pin needles
You can buy all non printet parts on HK:
- M2 x 25mm Steel Push Rod (10pc)
- Stand-off Ball Joints 2pcs
- Airplain / multirotor ESC 2s ca. 12Amp
- Turnigy Multistar Outrunner V2
- 5030 Carbon Fiber Propellers 2pcs
- Lipo 2S 1000mAh
- Female JST battery pigtail 10pcs
- 10CM Servo Lead Extention 10pcs
- Digital Servo 12g
- Hex Screw M3x14 (20pcs)
- Hex Screw M3x8 (20pcs)
- Screw M2x5 (4pcs)
- And a Radio
Step 3: Printing
Download the files from here
I printed all parts out of ABS on my modified tantilus 3D Printer.
The infill:
- Rear and front with 15%
- The control surfaces with 20%
- All other parts are printed with 50%
Step 4: Modifying the Control Curfaces
To mount the control surfaces heat a pin needle and put it in the top and bottom around 3mm from the rounded edge.
Step 5: Put Everything Together
Put everything together like in the pictures.
You must extend the Motor wires to run them to the ESC throu the cable duct.
For sealing the two main Parts are glued around the internal cable duct and the screwes.
Step 6: Also Graet for FPV ;)
I put in my small FPV setup and drive around like i'm sitting on it.
