3D Printed Tool WristBand W/ Minimal Assembly
Intro: 3D Printed Tool WristBand W/ Minimal Assembly
If you like my work please visit my Shapeways.com/shops/amznfx or my etsy.com/shop/amznfx and check out my other work
So i saw similar product on the market for 200 - 500 dollars on the internet. Not even sure is available for sale but i'm not sure if i want to drop that much money if i can make one myself.
So i went to work on my computer, drafted some 3D files, 3D printed some prototypes. However, the initial prototype i printed required screws and some assembly. I could have gonne to home depot and bought some screws but why should I? so maybe I could 3D print some screws and glue them in place. But it hit me.. I could 3d model the screws in place and i could 3D print the entire thing all at once.
So i went back to the drawing board and 3d model the whole thing. I also placed each link in a manner that maximizes the way it prints. This method pretty much allows me to print the entire bracelet all at once. The only reason i don't print the second part of the clasp all at once because i want to print it sideways to increase strength in the direction i wanted.
Materials
You will need a 3d printer or a buddy with a 3D printer
a head gun or blow dryer might work
screw bits.. i had a bunch just laying there
You can download the files here http://www.thingiverse.com/thing:753452
or you can just buy one from me https://www.etsy.com/listing/228631397/multi-tool-wristband
STEP 1: 3D Print and Assemble
I think i used 50% infill or less to keep the print strong and in the lighter side. I reduced the support to the minimum but i think you can 3d print the entire thing without support but dont quote me on that.
I picked the screw bits i wanted to use and had them ready for when the print comes out.
So here is the trick.. You have to be there when the print finishes and it still warm. start putting the screw bits into place while it still warm and do it quick or you will have to use a heat gun
This will be the easiest part but it will get a little complicated when you put the other half of the bits.
Remove the bracelet from the print bed and one by one heat up the hole and insert the screw bit into place.
Once you have all the screw bits into place 3D print the clasp.. and glue into place with the rest of the bracelet.
if the clasp is a little too lose heat it up and squish it to make it tighter.
20 Comments
pucksurfer 8 years ago
Thanks
BruceE3 9 years ago
Gratz
Whisper219 9 years ago
Nice job on this design! Quick question though: could I use something like a two-part epoxy to affix the bits instead of a heat gun?
mstyle183 9 years ago
right now its design to expand with heat and shrink when it's cooling down.. right now it's a bit hard to put the bits in while cold.. so if you like to do this maybe enlarge the print by .03 - .05 % to make the holes a big bigger.. then use epoxy to keep them in place
kondzio29 9 years ago
Good Idea, but you should consider smooothing the edges with sandpaper, beacuse it looks like it is not very comfortable to wear ;)
Omni DIY 9 years ago
Gonna print me one tomorrow I think! Great job!
I voted for you and am printing it now. My only note would be that the bracelet stl is oriented vertically. If you included the clasp and made its default orientation the same as the print orientation, that would be awesome. Keeping my fingers crossed on the print! I have an old gen 3 solidoodle that can be... erratic...
pucksurfer 9 years ago
Jake_Makes 9 years ago
sixsmith 9 years ago
The leatherman Tread to be specific, they announced it not too long ago, but it's way over priced for what it is, In my oppinion
oh yeah that instructable! I recall your mention of the troubles of licensing. I thought it was a great project, I don't own a smart phone or I'd have tried it myself.
ledio.prezzi 9 years ago
print it in pla and then soak it in aceton .. it will have a nicer fealing on the arm
BruceE3 9 years ago
cool!
