3D Red Barron From Hot Glue
Intro: 3D Red Barron From Hot Glue
Since the 3D printer first came out I have always wanted one but i haven't decided to buy one because of expense.
But, I have found a way around this barrier.
The way i have discovered uses the hot glue gun.
hope you like it.
STEP 1: What You Will Need
- A hot glue gun
- glue for the hot glue gun
- Knife
- Red paint
- Black paint
- White paint
- clean working surface
- paintbrush
STEP 2: Wings
dimensions
length:4"
width: 1/2"
How to make
To make the wings you must first heat up the hot glue gun
Glue a line 4" long and repeat this several time until the wing is 1/2" wide (I will refer to this as rows)
Make 3 wings because this is a triplane.
STEP 3: Body
Dimensions
Length: 3 1/2"
Width: 1"
Height: 3/4"
IMPORTANT: to make the cockpit don't put glue in the space
How to make
To try to make the body a oval shape you must use less rows of hot glue at the bottom say 2 and make your way up by putting more rows in the gaps of the first few rows.
When you are about three rows up you must continue at the front and back with the same technique but in reverse so you are shrinking the width.
In the middle leave a gap of about 1" for the cockpit.
When the rows are set at the top place rows at the edge of the cockpit leaving a rectangle of roughly 1" long 1/2" wide and 1/4" deep.
STEP 4: Tail Fins
Dimensions
Tail Flaps (Second Image)
Diameter of: 3/4"
Tail Fin (First Image)
Diameter of: 1"
How to make
Tail Flaps
To make these make the hot glue set in a spiral fashion to end up with a nice circular shape with a diameter of roughly 3/4".
Cut a flat zone into the side of each flap so it will make it easier to glue later on.
Tail Fin
To make this use exactly the same method as the flaps including the cut but just a bit bigger.
STEP 5: Preparing the Body
Choose one end of the body and cut two sides and the top of that end on a slight angle so you can glue the tail fins on later.
STEP 6: Painting
OK time to paint, Use a red colour to paint everything excluding the tail fin.
The tail fin is the only part to be painted white.
Paint the cockpit either black or grey, I chose to paint it grey.
Also in the gabs between the wings grey or black to resemble bullet holes.
STEP 7: Put It Together
For this nest step you must glue the tail fin, tail flaps and body together.
Use the flat zones you made earlier to glue the pieces together.
STEP 8: Wing Supports
Dimensions
Width: 1/4"
Depth: 1/4"
Height: 3/4"
How to make
This is just a single row of hot glue cut to 3/4" So you could simply do a single row 3" long and cut to size or 4 separate rows 3/4" long it is totally up to you.
STEP 9: Putting the Wings Together
To glue the wings on you place one wing on the bottom of the body and glue it in the middle of the wing at the front of the plane.
The second wing goes on top of the body, when this is glued on glue the wing supports about 1/4" from the end of the wings.
The third and final wing is glued on by the wing supports i found it easier to glue the wing supports to the third wing first then to the rest of the plane.
STEP 10: Propeller
Dimensions
length: 1 1/4"
Width: 1/8"
Depth: 1/8"
How to make
This is just a very thin row of hot glue, so it is pretty straight forward.
STEP 11: Machine Guns
Dimensions
Body of the gun
Length: 3/4"
Width: 1/4"
Height:1/8"
Barrel
Length: 1/4"
Width: As thin as necessary
Height: As thin as necessary
How to make
To make the Barrel it is a very thin row of hot glue cut to length
The body is just a normal sized row of hot glue
To glue the two pieces together place the barrel to the front of the body and glue it in this position
Paint it Black
STEP 12: Wheels
Dimensions
Diameter of: 1/2"
How to make
To make these it is exactly the same as the tail flaps or fin.
Except these are painted white and around the edge
I have painted black with a permanent marker.
If you want to have a rear wheel you must turn the plane over and at the rear put a dab of hot glue, and the dab is painted black
STEP 13: Wheel Support
Dimensions
Length: 1"
Width:1/8"
Height:1/8"
How to make
The Wheel supports main purpose is to keep the wheels straight so they don't fall off or break
So this is made just like the propeller but painted black
glue this to the inside of the wheels and glue the wheels to the bottom of the bottom wing.
STEP 14: The Cross
To add some decoration to the plane you can paint some crosses on the wings and tail fin
To paint the crosses on the wings you paint a white cross and then use a permanent marker to paint the black cross inside.
STEP 15: Finishing Touches
in all the places where you have not painted the hot glue paint them now.
STEP 16: Hope You Enjoyed
If you do decide to make this please put an image in the comment section.
Thank you
2 Comments
avocadostains 9 years ago
Youre a madman! best hotglue sculpture thing ever.
Madman146 9 years ago
thankyou
