Introduction: 3d Printable Multi Tool
This is a 3d printed multi tool. Not only does this include wrenches and a ruler it includes a retractable knife, a USB drive, and possible a thermometer. I use this almost everyday, whenever I open a box, need to cut something, or need to tighten so screws.
Step 1: Supplies
What will you need?
- At least one 3d printer
- at least one spool of PLA filament
- A USB drive component
- A box cutter blade
- Super Glue
- Slicer where you can control settings
- A snack
Step 2: Download the STL Files
Where to download the STL files?
- You can access the STL files on Thingiverse or click the attached STL file.
- Thingiverse
- Click this link and it should bring you to the correct page
- It should bring you to a page with the title multi-tool
- Download the "Thing File"
- Then upload it to you slicer and use the instructed settings
- Attached STL file
- Click the download button on the STL file below
- Then click this link to see the print settings
- Upload the file to your slicer and insert the print settings.
- Proceed to the next step
Step 3: How to Print the Parts?
Printing the Parts
- Download the STL files like in the previous step
- Set up the proper setting
- You can find them at this link
- Make sure you have a properly calibrated print bed
- You also need very good bed adhesion
- If you want it to also be a thermometer, use thermo-sensitive filament
- Once it is printed, remove it carefully from the bed
- You can then sand it as you wish
Step 4: How to Add the Box Cutter Blade?
Adding the box cutter blade
- You need to be very careful
- Slide the blade in where it would come out without cutting yourself
- It will get caught when you get to the first notch
- Pull up the locking mechanism and continue sliding
- Slide until the blade is fully covered and locked in
- BE CAREFUL it is a sharp knife, use at your own risk
Step 5: How to Insert the USB Component?
Inserting the USB Component
- Sand off the outside of plastic
- Make it as smooth as possible
- Put a drop of glue on the back edge of it
- Slide it through
- let it sit and dry
Step 6: What You Should Do Next?
Doing next
- Show your friend, please direct them to this page
- Also please post your make on the Thingiverse website
- If you have any questions, please feel free to ask in the comments
