Introduction: 3d Printed Earrings and Pendant Set (designed in Tinkercad)
How to create and print a beautiful pendant and earrings set using Tinkercad and a 3d printer
Step 1: Start Creating Your Earrings
Using the cylinder shape in Tinkercad create 6 identical cylinders 40x40mm and 2mm tall.
Rotate the cylinders 90 degrees so that they are standing on their ends.
Rotate cylinders by 30 degree increments
Step 2: Continue Shaping the Earrings
Create a ‘hole’ sphere 36mm diameter.
Align this with the cylinders and group
Step 3: Add the Detail
Create a cylinder 2mm diameter and 40mm tall
Create two pyramids with 8 sides, 10mm tall, flip one so that it is upside down and group the two together to create a diamond shape.
Align these shapes with the hollowed sphere and group
Create a small ring shape using the pre-set shapes and centre it at the top of the model, group everything and export as an stl
Step 4: Create the Pendant
Create the pendant using the same technique but using only two cylinders at the beginning
Step 5: Slicing Your Jewellery
Slice your earrings and necklace, adding variety by including colour changes through the print
Step 6: Print Your Jewellery
Print your jewellery
Both models print without supports, but I used a raft for extra stability
Step 7: Enjoy Your Creation
Ta Da, a beautiful pendant and earrings set to wear or give as a gift 😊
@3DPrintBunny
