Introduction: 3d Printed House With Interior Lighting
For this project I decided to model and 3d print a house. This project took weeks to complete, as well as many challenges and mistakes. Overall, I greatly enjoyed this project, and learned a lot from it.
By: Adam Gerhant, Student at Scripps Ranch High School
3d Modeling Tools
Fusion 360
(Files attached at bottom)
3d Printer
Dremel 3d45 Idea Builder
Paint
Rust-Oleum textured spray paint
Electronics
(A soldering iron and solder is also needed)
Step 1: 3d Modeling
3d modeling the house was very challenging as it needed to be split up into multiple parts that are possible to 3d print. First, I created the house as one file, to get an idea for how it needs to be split up into different pieces. Once this was finished, I completely remade the house as dozens of different pieces. I then scaled the files to enlarge the house.
Step 2: 3d Printing
Once the house was fully modeled, and the individual pieces were exported, I began to 3d print. The most challenging part of this process was that I had to use my schools 3d printers, but since there was a 3d printing project at school, I could only begin 1 week before the project was due. In order to finish printing as quickly as possible, and since there were 30 files that I needed to print, it was necessary to load many files onto one print bed. This worked out well, and I was able to load all the files onto 4 print beds, and finished printing in a few days. However, another challenge was that there was only black and blue filament available, so painting would be necessary.
Step 3: Washing and Painting the Parts
Due to the glue that was needed to keep the parts on the print bed, and imperfections with the prints, the parts needed to be thoroughly washed and sanded. Once this was done, I began painting the parts. This took much longer than I expected because every part has multiple sides and colors to paint, and only one side could be painted at a time.
Step 4: Assembling the House
Once the parts were washed, sanded, and painted, the house could start being assembled. First, I started with creating a base plate out of cardboard. I made holes for the switches and for the wires to go into the house from below. Then, I hot glued the switches, and soldered the wires to the switches. Next, I could begin assembling the house. Using the fusion file as a guide, I started hot gluing the pieces together. At the same time, I also was soldering the wires to the LEDs, and running the wires through the house. Unfortunately, I ran out of spray paint at the end, and after going to multiple hardware stores, I was not able to find another bottle.
Step 5: Conclusion
In conclusion, I am very satisfied with the result of this project. The house turned out just as I expected, and am glad that I could finish on time. I learned how important it is to always leave plenty of time to finish projects, because there will always be some delays.
1ALL PARTS.stl
3combined front wall_Scaled.stl
5front floor_Scaled.stl
7front right floor_Scaled.stl
8front right wall_Scaled.stl
9right side floor_Scaled.stl
10front bottom side wall_Scaled.stl
11side back wall_Scaled.stl
12stairs_Scaled.stl
13back right wall_Scaled.stl
14back bottom floor_Scaled.stl
15back left baseplate_Scaled.stl
16front left baseplate_Scaled.stl
17back right baseplate_Scaled.stl
18front right baseplate_Scaled.stl
19back right pillar_Scaled.stl
20back wall_Scaled.stl
21left wall_Scaled.stl
22right inset wall_Scaled.stl
23side porch cover_Scaled.stl
24back upper floor_Scaled.stl
25balcony_Scaled.stl
26back top feature_Scaled.stl
27stair railing_Scaled.stl
28left roof_Scaled.stl
29right roof_Scaled.stl
30top roof window_Scaled.stl
31back roof_Scaled.stl
