Introduction: 3d Printer Bed Leveling Jig
This is a simple bed leveling jig using simple and cheap parts.
All we need are a tiny magnet, a T-slot nut and a metal ruler.
M4 Slide in Economy T-Nut Block https://www.amazon.com/80-20-14159-Slide-Economy/d...
Metal Ruler https://www.harborfreight.com/hand-tools/measurin...
Step 1: Remove the Y Axis Bearing.
Use the allen wrench included with the printer to loosen the screws holding the tensioning bearing in place and insert the T-nut.
Step 2: Attach the Ruler to the T-nut
Use the magnet (or use a piece of a magnet) to hold the ruler onto the T-nut.
Step 3: Use the Screws to Adjust the Level Using Bed Visulizer to Aid Leveling
Now just move the ruler to each corner and adjust it until all 4 corners the same height on the ruler and check your progress on the Bed Visualizer in Octoprint. It's usually good if you have it within a millimeter. Now just put it back together and get printing!
Tip: use a hefty enough ruler that it moves with the bed, if its too light it will be a pain.
