Introduction: 3x3 Piston Door for Bedrock 1.21.0 (or Education Edition)
Heres how to make a 3x3 piston door for bedrock edition 1.21 (or Education Edition)
Here are the items you need, your door blocks and blocks to build with are not included
Step 1:
Build a 3x3 hole (corners cut out) 3 blocks above the ground.
Step 2:
Place your sticky pistons like this (I used the RedrefinedRS texture pack in this image).
Step 3:
Add a Dropper, a solid block, and a observer next to the dropper. Add a 4 tick repeater facing toward the sticky piston as shown. The solid block is where your input is.
Step 4:
Add a normal piston below the dropper, a redstone block, 2 observers facing upward, leave a one block gap, and add another piston as shown.
Step 5:
Place an observer facing away from the dropper (crouch if needed) and another observer belowfacing toward the piston.
Step 6:
Then, 1 obsidian, and redstone dust underneath. The piston will fire, so replace the blocks on step 4 back to its original position.
Step 7:
Place a redstone torch next to the input block, then a piston (or sticky piston) facing downward with another torch on top of that.
Step 8:
Add an observer next to the redstone torch that is off.
Step 9:
Add obsidian on the botton left of the foor frame as shown.
Step 10:
Place a solid block on top of the redstone torch that is off, and then 2 redstone dust on top of the solid block and the sticky piston.
Step 11:
Place glass and more redstone dust.
Step 12:
Then, slap a 3 tick repeater and a solid block.
Step 13:
Place 2 solid blocks with redstone dust, and 3 glass with redstone dust as shown.
Step 14:
Add an observer facing downward next to the obsidian, 2 solid blocks below, another solid block on the bottom sticky piston, and 2 redstone torches (place from bottom to top).
Step 15:
Add an observer facing downward (dig blocks if needed) and redstone dust. (If you are out of redstone dust use a solid block instead).
Step 16:
Believe it or not, that is your 3x3 piston door complete! This door can break, but it will fix itself with a simple close and open. =)
Step 17:
With some decorating, your door is complete!
