Introduction: 4 Person Pong
I made a 4 person pong game because It allows me to play pong with multiple people at once. I also am a freshman at Kirkland ranch academy of innovation.
fusion 360 units: inch's
Step 1: Creating the Platform
create a 24 by 24 platform. create another sketch on the side and from the bottom go up 1 inch create a 22 by .5 sketch and leave 1 inch on each side. and then on top create a 22 by .5 and leave a 1inch on each side. and do the same on the other side. then extrude the top center of the shape down 1.5 inches to cut.
Step 2: Creating the Bumper
create a 2 inch circle and extrude it up 2 inches. now create a sketch in the side and make it a 1 by 1 square in the center. extrude it both direction to cut out a hole.
Step 3: Creating the Ball
you will create a circle and put a line through the middle and trim of the other end you should have a half cycle. the revolute the have circle and you have a ball
Step 4: Putting It Together
create a new file and insert each design in the file(insert the bumper in 4 times). next you will need to ground the platform. then make a sliding joint on all the bars with the bumpers. and put the ball in the middle. and
done.
