Introduction: 4 Tips to Perform Embalming Successfully
The pain when a close person passes away is extreme. Yet, there’s
a necessity to let go of the bonds. And the body of the deceased person is also taken away for funeral. And this funeral process is completely different for various religions and cultures. While most of the races across the world do away with the dead bodies, there are a few who store it as well. And in a strange way too. This process has been around for thousands of years. It can be found in history as well. A perfect example for such a case is the way in which the Egyptians used to store the bodies of their near and dear ones. However, these days as well, the bodies need to be kept in store, as many of them are necessary for medical studies. So, to store the bodies properly, it is necessary to embalm them. Even various organs are also embalmed separately.
Being Properly Dressed for Embalming
Embalming is a tedious process. And if you are the embalmer, you need to be properly prepared for the procedure. The best way to start this is to get the right kind of costume for it.
So, how are you likely to begin planning for the costumes of embalming?
Remember, splashes of blood, embalming fluid, or even urine can occur during the process. So, the best solution is to get the body properly covered. You should find a costume that covers almost all parts of the body. This should include covers for the body, arms, and legs. You should also go for a cover for the shoes. And the costume set should also include a helmet, which covers the face with a see-through fiber sheet. These are going to come in extremely handy to save the body from splashes of blood, urine, or the embalming fluid.
Instruments Necessary for Embalming
Embalming is quite closely related to anatomy. And a bit of dissection of the body is necessary if you are looking going to embalm a body. So, if you are going for an embalming process, you are likely to require a lot of instruments. And many of them are associated with dissection of bodies as well.
So, what are those instruments, which are likely to make the process of embalming easier for you?
These might include:
· Barb
· Needle injector
· Angle scissors
· Autopsy aspirator
All these instruments are among the most important equipment, which every embalmer should possess in his or her kitty. And they should be kept handy during the procedure. In addition to these instruments, a few body blocks are also extremely necessary. If you are looking to make embalming easier, you’ll have to place different body parts on the blocks meant for those parts. For example, you will need a block for placing the head, another couple for the arms, and so on.
Table Necessary for the Embalming
It is important to get a proper base to keep the body on while performing embalming. So, you should get a proper table for the purpose. There are different types of embalming tables available. All you need to do is go on a quick search in various shops. You might even find an embalming table for sale if you are looking online for it.
Type of Embalming Table You will Need
What kind of embalming table will come in really handy for you?
It will be a wise decision to go for lofted stretchers. You will be able to keep the body in a completely stretched form on it. And the wheels at the bottom of the stretcher will be extremely helpful if you need to move the body around to make the process of embalming easier. Besides, a shelf just below the bed or stretcher can come in handy to place all the necessary instruments. This is going to make it easier for you to complete the embalming process quite easily.
Embalming has been in practice since the earliest times. It is quite a necessary process even to this day, especially in the field of medical science. So, if you want to perform embalming, it is important to set it up properly to get the process done with success.
Step 1:
