Introduction: 4 Ways to Lace Shoes
About: ~Iowa USA~17~ @KikiMariePhotography (on Instgram and facebook) ♕Christ is King ♕
Here are four different ways to lace your shoes!
Step 1: First
First, I'll explain how to do this one.
Step 2: #1
Put the laces through the bottom like this, evenly.
Step 3: #2
Tuck the middle behind the tongue.
Step 4: #3
Skip one of the holes, and pull the left lace through, as shown.
Step 5: #4
Pull it through, then under into the empty hole under it.
Step 6: #5
Do the same with the right side.
Step 7: #6
The repeat that same process above it.
Step 8: #7
Then pull the laces through the top, and tie them under the tongue. Or tie them as you normally would.
Step 9: Finished!
Thats it for this one. :)
Step 10: Second One
I think this one looks the coolest.
Step 11: #1
Pull both laces through the left side, evenly.
Step 12: #2
then pull them over the top, and go through the right side, as shown.
Step 13: #3
Skipping a hole, pull one of the right strings through.
Step 14: #4
Do them both.
Step 15: #5
Then pull both strings through the empty holes.
Step 16: #6
And weave them one on top of the other like this. Its quite simple. Then shove the laces under the tongue, or tie them as you normally would.
Step 17: Third One
This one was kinda hard for some reason, but hopefully I can explain it well enough!
Step 18: #1
Pull both laces through one side like this.
Step 19: #2
Take the bottom lace, and pull it through the top one on the opposite side.
Step 20: #3
Then take the other lace and go through the other side directly across .
Step 21: #4
Then go through the other side and come back.
Step 22: #5
Continue going up, as shown. then tie them off. Thats it!
Step 23: Fourth One
This is actually the easiest one.
Step 24: #1
Pull the laces through evenly like this.
Step 25: #2
Then cross them, skip a hole, and go through. (just lookit the pictures.)
Step 26: #3
then go back through the oposite hole so that the laces overlap each other.
Step 27: #3 Continued
Like this.
Step 28: #4
Then just repeat the same thing over and over. Its very simple. I'm sure you'll figure it out really quickly.
Step 29: Thats All!
Thats all of them, I hope you can figure them out!! :)
