Jeep Wrangler 4 Door Rack
Intro: Jeep Wrangler 4 Door Rack
This is a quick door rack to keep your jeep doors safe when you are driving around doorless.
Seemed like a good first instructable. :-)
STEP 1: Parts
From Home Depot:
4 - 10' X1" PVC pipe
6 - 1" pipe insulators
14 - 1" PVC elbows
10 - 1" PVC TEEs
Cost about $35
Cut the pipe into 10 - 2' sections,
8 - 4" sections,
and the rest into 1' sections.
14 - 1" PVC elbows
10 - 1" PVC TEEs
Cost about $35
8 - 4" sections,
STEP 2: Put Together the Verticles
Connect two 2' sections and one 1' section with elbows.
Do this 5 times.
Do this 5 times.
STEP 3: Start the Base
Create two base sections each with a TEE, 1' section, TEE, 1' section, TEE.
Before you press them together too hard make sure that all of the TEE sections are pointing down and flat on the ground. This will help to ensure they all point straight up.
Then connect three of the vertical sections into these.
STEP 4: Cross Members and Ends
Create two sections each with a 4" section, TEE, 4" section, elbow.
Then connect the two sections at the TEE with a 1' section.
Connect this to the one end of the main base and add a vertical upwards from the elbows.
Repeat this on the opposite end.
And look at the pictures... its easier than reading all this. :-)
STEP 5: Foam It Up!!
Cut the foam pipe insulators to fit every section of 1" pipe you can.
The insulators are split down the middle and are self adhesive so you can cut them, wrap them around and secure them in place very easily.
The foam insulators are just a bit wider than the elbows and tees so the doors can rest against them without rubbing PVC.
STEP 6: Go Doorless!
Take your doors off!!! The two front doors lean in against the center vertical section. The two back doors go in the outer slots. I put them on their side since the bottoms of the doors are pretty narrow. They made me nervous. :-)
Looking back I could have made the width of the rack a little less so that the rear doors would have a better span, but I suspect they would still be prone to bumps or wind.
Hope you enjoyed my first Instructable!!! Have fun building it, and if you don't have a Wrangler, go buy one!!! :-)
STEP 7: Addendum
I modified my rack some today. I shortened the distance between posts to 6" and cut the height down to 19" this keeps the vertical posts under the mirrors and door handles allowing them to fit in the 6" space. I also mounted it to a furniture dolly so it can roll around. I glued it all together with PVC glue to help stiffen it as well.I modified my rack some today. I shortened the distance between posts to 6" and cut the height down to 19" this keeps the vertical posts under the mirrors and door handles allowing them to fit in the 6" space. I also mounted it to a furniture dolly so it can roll around. I glued it all together with PVC glue to help stiffen it as well. I modified my rack some today. I shortened the distance between posts to 6" and cut the height down to 19" this keeps the vertical posts under the mirrors and door handles allowing them to fit in the 6" space. I also mounted it to a furniture dolly so it can roll around. I glued it all together with PVC glue to help stiffen it as well. I modified my rack some today. I shortened the distance between posts to 6" and cut the height down to 19" this keeps the vertical posts under the mirrors and door handles allowing them to fit in the 6" space. I also mounted it to a furniture dolly so it can roll around. I glued it all together with PVC glue to help stiffen it as well. I also added a couple of velcro straps just to keep the doors together while rolling around the driveway.
36 Comments
jivan89 4 years ago
Also my foam is not self adhesive so it’s just hanging on, anyone know what’s good adhesive to use to have them stay on the PVC?
Thanks a bunch
R0dr0c 1 year ago
jivan89 1 year ago
smokinjoe37 1 year ago
Step 1: parts list from Home Depot:
3 ea. 10' X1" ID PVC pipe
6 ea. 1" pipe insulators
(pool noodles)
14 ea. 1" PVC elbows
10 ea. 1" PVC TEEs
Step 2: cuts
-For verticals and crossmembers:
10 ea. 16 1/2" sections
7 ea. 12" sections
-For base:
4 ea. 7" sections
8 ea. 3" sections(for TEEs at ends)
Final dimensions without foam, approximately 19" tall, 15 1/2" wide and 36" long.
Step 3: Assemble Verticals:
Connect two 16 1/2"sections and one 1' section with elbows.
Do this 5 times.
Step 4: Start Base:
Create two base sections each with a TEE, 7" section, TEE, 7" section, TEE. Before you press them together too hard make sure that all of the TEE sections are pointing down and flat on the ground. This will help to ensure they all point straight up. Then connect three of the vertical sections into these.
Step 5: Cross Members/Ends:
Create two sections each with a 3" section, TEE, 3" section, elbow. Then connect the two sections at the TEE with a 1' section. Connect this to the one end of the main base and add a vertical upwards from the elbows.
TylerF3 1 year ago
LloydF3 8 years ago
Only needed 3 of the 6' foam insulators. I spray painted the PVC before putting the insulation on too.
nboudreaux07 2 years ago
LloydF3 2 years ago
ayalamm23 3 years ago
k3po.mcdonald 3 years ago
16 3/4" = 10
7" = 4
3" = 8
12" = 5
You will also only need 30' of pipe and will have 55" remaining. Final dimensions without phone 20" tall, 15 1/2" wide and 36" long.
taagerickson 3 years ago
ScottHood24 3 years ago
despositoj 3 years ago
mgre21 3 years ago
iamjustjeff 4 years ago
TXDad1406 7 years ago
How did you secure it to the dolly? Thanks
JodyD24 5 years ago
Looks like he used a 1' metal electrical tube strap. You can find them at Lowes or Home Depot for a couple of dollars.
https://www.homedepot.com/p/Halex-1-in-Electrical-Metallic-Tube-EMT-2-Hole-Straps-4-Pack-26163/100117640
benhendricks 5 years ago
MikeS744 5 years ago
Instead of:
10 - 2' sections,
8 - 4" sections,
What should the cuts be to make the final result?
