Introduction: .410 Gauge Shotshell Keychain
Easy keychain i made about 3weeks ago
Step 1: What You Need
What you need:
-empty .410 shells
-Knife
-Little Chain or keyring
-dril or screwdriver
-9mm casing
Step 2: First
Get 9mm casing and insert in 410 shell for some weight and so you don't bend plastic when cutting shell
Step 3: Cutting
Make a mark about 1/3 of an inch above 9mm then get knife and cut small slot
Step 4: Making Hole
Get Screw And Drill or Driver (i used sheet metal screw but any will work) then screw into where you cut small slot. once yo make the hole you can file it down to make it smooth
Step 5: Final!!!!
Cut a little above hole and cut top off then put chain in hole attach to key and your done
Step 6: Watch My Other Instructable
Thank You for watching
