Introduction: $42 Static Lift Exercise Gym
Weight equipment can cost hundreds to thousands of dollars. It takes up tons of space and there is more than ample opportunity to injure yourself.
For $42 I've designed a device that can get you the same level of workout. It rolls up and can be tucked away in the space between your dresser and the wall. AND the chances of hurting yourself are practically nill because there is no actual weight involved.
PLEASE NOTE!! I am currently in the process of applying for a patent on a slightly more complex version of this device. But I figured instructables was the perfect place to share my prototype.
It works the same way as a static lift, or basically a lift where you just hold massive amounts of weights without moving it. I will go more into the science of how it works in the next step.
I'd like to give a shout out to my friend Justin. One day he discovered the method of training that inspired me to design this. I figured why use hundreds of pounds of weight when we could simply use our bodies?
Step 1: How It Works
The idea is fairly simple. You have a bar with two chains that attach it to a base plate. You stand on the base plate and lift against the bar. No matter how hard you lift that bar will not budge, but believe me you will feel it in your muscles!
Resistance training has been around for ages. For an example press your hands together in from of your chest and press as hard as you can. You will feel your chest muscles flare up. THAT is how this things works.
The chain adjusts in length at the base plate so that you can do different lifts with different lengths of chain. Simply determine the height it needs to be and lock it in. Then lift like you were trying to rip the entire thing to pieces.
This kind of lift is called a Static lift, in that it does not move. Normally you would do a static lift on a traditional weight bar by stacking up as much weight as you can physically handle and then holding it up for 5-10 seconds. This engages more types of muscle (fast twitch and slow twitch) than regular repetition. With this device you don't need to guess what you max is, simply give it your all. .
One thing to keep in mind is that each lift is held at the Strongest Point of a lift. For instance in bench press if your arms are bent at 45 degree angles you have very little power, the closer to being strait they are the more power you can generate. It's an issue of leverage. The straighter your body the more power. In all my examples we demonstrate the strongest point of that lift.
So how do you work out exactly?
I will describe one of many ways this can be used. This method is loosely based off the Static Contraction Lifting system designed by a weight lifting genius Pete Sisco (Look him up, you wont regret it). He used biology and mathematics to work up a system with the least amount of work for the greatest amount of gains. I wont go into details but do yourself a favor and look him up, he has several books published.
NOTE: due to the unbelievably amazing claims people tend to disbelieve his system actually works. But if you do some research there is tons of evidence it does. I myself use it and it seems to be working great. Regardless if you believe or not this device can still give you a great workout.
For each lift described later in this instructable only do the lift ONCE. I know, too easy, right? If you feel must, you can do more but science shows once is all you need. Simply enter the lift and hold it for 5-10 seconds lifting with all your might. Try to break the chain!. After 5-10 seconds exit the lift, shake your limbs a bit and then set up the next lift.
It's recommended to only do each lift once a week. This gives your muscles enough time to fully repair. When you use them (heavy loads, not day to day stuff) twice a week or more you are actually slowing the recovery time and making it harder to grow muscle.
SO: if you want you can do all the lifts in one sitting once a week. Or to gain even more benefit split them up into two separate workouts. Do one one day, wait a few days and then do the other. For Example:
Mondays:
Overhead Press
Curls
Dead Lift
Wide grip bench press
Thursdays:
Squats
Shrugs
Calf Raises
Close Grip bench press
Again this is but one example. Do some research and decide on a workout that works for you.
Now, to the fun part!
Mondays:
Overhead Press
Curls
Dead Lift
Thursdays:
Squats
Shrugs
Calf Raises
Step 2: Supplies
Supplies you will need.
The cost of each item was recorded from my local hardware store, it may vary where you are.
1pc - 2"x8" piece of Hardwood eight foot long. Cut in half. --------------- Price: $6.24
1pc - 1" conduit pipe found in the electrical section Cut to 4 foot long. Price: $6.89
15' - Welded strait link chain weight capacity of 545 lbs. $1.10/foot -- Price: $16.50
4pc - Eye Bolts. Zinc plated 5/16" by 4" - $0.67 each ------------------ Price: $2.68
8pc - 5/16" Nuts at $0.10 each -------------------------------------------------- Price: $0.80
6pc - 5/16" washers at $0.10 each --------------------------------------------- Price: $0.60
2pc - 5/16" Fender Washers at $0.15 each ---------------------------------- Price: $0.30
4pc - Quick Links (660 lb load) at $1.99 each ------------------------------- Price: $7.96
TOTAL COST ------------ $41.97
Other things you will need
-Something to cut the wood, chain and pipe (all of which can be done at time of purchase at most hardware stores)
-Electric drill or drill press
- 5/16" drill bit
- 1-1/2" spade bit
-JB weld or someone who can weld
- 5/16" drill bit
- 1-1/2" spade bit
Step 3: Sealing the Eye Bolts
When you purchase the eye bolts they will most likely not be a solid ring on the end as you see in my picture. If you have access to someone who can weld have them close it. If not slap on a glob of JB weld epoxy.
IF YOU DO NOT.... then the weight rating is not enough to hold up to extended use.
do not skip this step!
Step 4: Making the Bar
Using 1 inch conduit cut a 4 foot length. You can ask the guys at the hardware store to do this. If they say they don't know how go over to plumbing and ask them.
Once you have your 4 foot section measure in and mark 3 inches from both ends. On these marks drill a hole strait through with your 5/16" bit.
NOTE!! Make sure that both your holes are parallel
Now take one of your eye bolts and attach them like in the picture.
For those who can't see the picture you have threaded onto the bolt : nut - washer- pipe - washer - nut
Set up both sides like this.
This here will be the bar that you hold onto for all your lifts.
Tip: After you have made the entire thing and made sure it works go back and use either super glue or thread lock on all the bolts. You don't want them coming undone during a lift
Step 5: Drilling the Board
A note about the wood. You MUST use hardwood. The hardwood will be plenty strong unless you are an Olympic class lifter. Softer woods however will be too weak and rip through. Also the board in my pictures was only a 2x6. After making it I realized a slightly wider base would be much easier to stand on. If all you have is a 2x6 though it will work just fine.
Onward!
3 inches from both ends of the board drill a hole with your 5/16" bit.
Then using your 1-1/2 inch spade bit recess a small hole just barely deep enough to fit the fender washer and a nut. Try not to go any further than this as it weakens the wood
NOTE!! Only recess one side of the board, this will be the bottom.
Onward!
Step 6: Bolting the Board
Now attach your eye bolts to the bottom On the top of the wood use a nut and a regular cut washer. On the bottom use a fender washer and a nut. Try to thread it perfectly flush on the bottom since this is facing the floor. Too long and it will make your base plate rock back and forth.
After that attach a quick link to each of the 2 eye bolts.
This is the base plate uppon which you will be standing.
Step 7: Choosing the Chain
When picking out your chain look closely at the load limit. Go for at least 500 lbs. I got 545 lb chain.
The reason you need so much is that this equipment is used to train at the strongest point of a lift. If a person can bench press 135 lbs than at the strongest point of their lift they could probably lift 300 lbs. The reason the full lift is so much less is because at a certain point your joints are at a weak leverage point. In general the straighter your body and limbs are the stronger they are.
For an example me and my body builder friend stacked 625 lbs on his leg press (that's all the weight we had) and were easily able to do mini 6" reps with it.
Now with this project there are 2 chains so your weight limit doubles from 545 to 1090 lbs.
ALSO it helps if you put a piece of tape or zip tie every 5-10 links. This make it much easier to line up the two sides later when you are adjusting the length of the chain.
Step 8: Attaching the Chain
Using the quick links attach a chain to each side of the bar. The chain will never have to be adjusted near the bar so simply attach and leave it there.
On your base plate (the board) the chain will be constantly adjusted in length for different lifts. Once you determine how long you need your chain to be use the quick link to attach the chain at that point.
Congratulations!! You are now done!!
NOTE!! Make sure your quick links are always tightened before a lift. A loose quick link looses it's load limit and can be bent out of shape with enough strain.
Step 9: Odds and Ends
Fist thing in this step you need to make a cushion for your shoulders for lifting Squats and calf raises. Without it the bar will dig painfully (but not dangerously) into your shoulders and neck.
To make this take you pipe insulation and cut two pieces. One piece 18 inches and the other 17. Wrap the 17 incher around the outside of the 18 incher and wrap the entire thing around the bar.
The Next thing to address is the back board for the bench press. No work required here. You remember how we cut the 2x8 into two 4 foot sections? Place the second section against your base plate like a T and place a pillow or couch cushion above it all for a head rest. (see the picture) You only need these parts for the bench press.
Step 10: Lift 1: Overhead Press
Lift # 1 - The Overhead press.
This exercise works out your shoulder muscles.
Stand perfectly straight with feel shoulder width apart. Your elbows should be just slightly bent. Press strait up at hard as you can. Make sure your wrists stay straight and don't roll back at all.
Step 11: Lift 2: Calf Raise
Lift #2 the Calf Raise
This exercise works out your calves, the small round muscle on the back of your lower leg.
To do the lift place the bar across the back of your neck and shoulders. Stand perfectly strait with your feet shoulder width apart. Press down with the ball of your foot to raise your heel slightly.
NOTE: This lift may take some practice if you find it difficult to balance on the balls of your feet. Keep at it though, it's well worth it!
Step 12: Lift 3: Squat
Lift #3: The Squat
Considered by many to be one of the most beneficial lifts ever. The main muscle you should be feeling the burn in is your quads (front of your thighs)
NOTE: if you want it is recommended to wear a weight belt with this lift. Since we have taken out the actual weight issue I don't know if it's still required. I'll have to ask my friend next time I see him
To do this lift you will have the bar lying across your neck and shoulders. Hold the bar just to help steady it. Your butt will be back slightly and your knees bent. Lift with your legs, not your back.
Step 13: Lift 4: Shrug
Lift #4 the Shrug
This workout hits your Trapezius muscles, the muscles between your neck and shoulders. Very important for fortifying the neck and they make you look like a bad ass (among other benefits).
To do this stand strait, feet shoulder width and hold the bar with your arms all the way down. Lift with your shoulders ONLY. Shrug them like when you don't know the answer to a question.
Step 14: Lift 5: Dead Lift
Lift #5 the Dead Lift
This lift works out your back. That part of you that always loves to go out once you hit your mid twenties. A strong back is an essential for a healthy pain free body.
NOTE: This lift it is recommended to use a weight belt. Again I'm not certain if it's necessary but hey, why gamble with your back? Even one of the elastic ones would help.
To do this lift stand with legs shoulder width or slightly over, bend your knees and lean your back forward just a tad. Grab the bar with arms strait down and lift with your back.
I'll say again lift with your back, not your legs or arms. Keep your back strait the entire time (lean forward but keep your back strait)
Be careful with this lift, don't press yourself too hard. The back is a fickle thing and easy to throw out. Still I would highly recommend this lift, the stronger your back the less likely it will go out on day to day tasks
Step 15: Lift 6: Seated Curl
Lift #6 The Seated Curl
The Curl works out your biceps, the muscle on the front of your upper arm.
We found you get a better curl when seated. To do this get a chair with 4 legs. Place the first two legs on top of the base plate as illustrated. This allows the downward force to travel through the chair legs rather than your feet and holds the base plate in place.
Now sit in the chair. Your upper arms should be perfectly aligned with your torso and your forearms at about a 45 degree angle. Your grip should be at shoulder width. Keep your elbows tucked close to your body and lift as if trying to touch the bar to your collar bone.
Step 16: Lift 7: Bench Press
Lift #7 The bench press
There are two variations of the bench press that we will go into here.
1. Wide grip bench press. By gripping as wide as you can you work out your chest muscles.
2. Tight grip bench press. By gripping about 10 inches apart you work out your tricep muscles. The muscle on the back of your upper arm.
Regardless of which grip style you use the lift is basically the same.
First place the 2nd board and pillow in place as describes in step 8. Now lay down ontop of it all, the base plate should rest at the bottom to slightly under your shoulder blades. Try lifting gently to get a feel of where it's most comfortable. Your head should rest on the pillow. Now press strait up from your chest, Your elbows should be slightly bent.
If you are using wide grip try to focus on you chest muscles working. If you are using tight grip focus on your triceps.
