Introduction: How to Build a 433Mhz Band QFH Antenna With Free 3D Files
ADMIN stop deleting the post without a reason!!! if you have problem DM me..
In this video we take a look at #howto #build a #QFH antenna for the  @tinygs  and  @SatnogsOrgProject  #communities, this #433mhz band antenna is a custom dielectrically loaded antenna which is the reason for its size reduction. this is a wanted attribute since some opperators do not have to option to install large antenna's outside the homes.
This is the first in a series of antenna's aimed at the Satellite tracking community and will be a work in progress untill the prefect option is found.
Community to track Satellites
tinygs.com
Files are made available on thingverse.
1) ThingVerse STL Files https://www.thingiverse.com/thing:5878204/files
2) QFH Calculator used http://jcoppens.com/ant/qfh/calc.en.php
Amazon links
1) Coax RG316 https://amzn.to/3Syml7N
2) SMA Connectors and Crimper https://amzn.to/3ISZoce
3) Copper Tubing https://amzn.to/3KB0cnr
Files and Calculators
Step 1: Pruchase or Source All Necessary Parts
Print the Files attached
and follow the amazon links to purchase the supplies needed or modify the files as you like and remix the design
Step 2: Video Instructions
Follow the step by step instructions in the video and be carefull! this takes some doing.
But if you do it right you may end up with an amazing and small antenna for its intended freqeuncy
Step 3: Test Your Device on VNA of Your Choice
Test your antenn on VNA tester to make sure your antenna will perform as intended
Note: Calibrate your VNA for the desire frequency and when possible always try test your antenna in its final location and with final coaxial cable
Step 4: Real World Testing
The QFN Antenna is a great choice for omni directional applications but it can have a very narrow band. So you need to always test the antenna in the real application to see how it performs. A good test is to compare the results again a known good antenna like the 1/4 wave ground plane antenna
