Introduction: 47 Projects to Do With a 555!
These are a whole bunch of things to make with the 555 timer IC with a note for each picture.
I do not take credit for these schematics, they were made by Collin Mitchel.
As you would probably think it took me a very long time to make this but it was night and i was wanting to waste some time so i hope you like it!
I have descriptions for each and every picture so feel free to ask questions!
2 People Made This Project!
- SHOE0007 made it!
- ponchbelly made it!
119 Comments
1 year ago
Vďaka za veľmi poučné, ako základ pre mladých amatérov.
10 years ago on Introduction
All these circuits were drawn by me: COLIN MITCHELL
See my website: talking electronics.com
and 555 circuit eBook with descriptions of the circuits
http://www.talkingelectronics.com/projects/50%20-%20555%20Circuits/50%20-%20555%20Circuits.html
Reply 1 year ago
السيدكولين لك خالص احترامي وتقديري وجزيل الشكر
Reply 5 years ago
mr Collin,
Thank you so much sir.
i just dloaded your book, and will try it out.
Wannaduino
Colin, I recognized your drawings immediately and wanted to point out this author's source from which the drawings were shamelessly copied, then saw that you already did, and it seems that nobody cares... the dark side of open sharing I guess... at least the link you gave will expose your generously informative website to some new readers.
Actually I emailed him and asked permission to use these schematics which he allowed.
Reply 6 years ago
And you did give him credit.
Thanks Colin,,, Awesome designs you have here!!!! Unfortunately the Designer of the 555 chip Hans Camerzind passed away Recently,,His Design of The 555 chip made it a Household Name!!! The 555 is still one of the most widely used I.C.chips in the history of I.C. electronics!!! Actually with all the circuits we have here I Don't know which one I want to Breadboard Here!!!
Mr. Colin55
My name is Mike
I have a question or a favor for you maybe you can help me. Thanks in Advance
I am in the process of making a board game called shut the box it's a dice board game. I'm sure you have heard of it for my daughter. Instead of flipping wooden numbers I would like to use some type of ic numbers 1-9 that are fixed so all I have to do is push a button coresponing to the specific number to turn it on or off if you look at google images under shut the box to get a better idea of what im talking about. any help would be greatly appreciated you can email me at mag200181@gmail.com
thank you so much
Sir i need some helpful material for music box. Kindly provide how it works?? waiting for ur reply. smya_tripathi24@rediffmail.com
Question 1 year ago on Introduction
Gostaria que fosse esplicado cada diagrama
Tks, friend!
Could you do a circuit for desalphating 12 volt lead acid battery up to 250 amps please with component spec and sizes
My email is hercules@viljoenhome.co.za
Question 2 years ago on Introduction
can I see the description of the metal detector circuit?
3 years ago
Those circuits are awesome useful, but i suggest to follow instructions on their original website http://www.talkingelectronics.com/projects/50%20-%20555%20Circuits/50%20-%20555%20Circuits.html You'll find all informations there. This is not an instructable, as the author say it's only wasted time ;-)
4 years ago on Introduction
May I see a description for the Servo Tester?
Question 4 years ago
Can any one explain the working of traffic light with two 555 based on mode of operation of 555
Answer 4 years ago
So the left 555 times the Red LED when pin 3 is low which resets the right 555 pin 4.
When the Red LED times out pin 3 goes high which allows right 555 to start timing by first pulling pin 7 momentarily low (normally to discharge a timing cap) which causes the Orange LED to light followed by pin 3 going high turning Green LED On...
Until the right 555 times out Green goes off as pin 3 goes low and the Orange LED goes on as pin 7 low goes to discharge..
Then sometime later the left 555 times out pulling its pin 3 low
turning on the Red LED On and resetting the right 555 ...
4 years ago
FOR I TO DOWNLOAD 555 TIMER PDF, AM REQUIRED TO SIGN UP. I DO NOT HAVE THE DOCUMENT WHICH ARE REQUIRED. HOW CAN YOU HELP PEOPLE LIKE ME
Question 4 years ago on Introduction
Can I get all 54 circuits to build?.
Warren
section515@juno.com
