Introduction: 4Pin RGB Controller
This Project is to Controll a 4Pin RGB Led Strip with a Wemos D1 Mini via Webinterface. If somebody needs help you can write an E-Mail to felix.nzgleisdorf@gmail.com
1* 15W 12V Power Suply
1* 4 Pin RGB LED Strip
1* Wemos D1 Mini
6* Mini Screws
1* 4 Pin Connector
1* 10 Diode
1* LS 7805
3* BSS 138
2* Capacitor
1* Bredboard
Step 1: Soldering
First you have to Solder all Parts togehter.
Step 2: 3D Print
Now you can 3D Print the case and the cover of the case. And screw the Bredboard down
Step 3: Programming
Program the Wemos D1 Mini.
Step 4: Programming
Give the Network ID and the Password in the Bracket and define your Pins.
Step 5: Time Control
Type in the time when the Led goes on or off.
Step 6: IP
Find the IP Adress of your Wemos D1 Mini in the control pannel of your Router and type it in the Browser.
Step 7: Timer
In this Bracket you can type the minutes until turn off after this time the led will turn off.
Step 8: Finish
Try it out and have fun.
