Introduction: 4th Period T2 Instructable Project Mask
This is my main project for my fourth period class in high school and it is a mask so that you can prevent the spread of covid-19 so I thought I could do a better job at making a mask but it didn't go so well it ultimately costed over 15 dollars to make one mask but even then it did not work. In the end it took me about 30+ hours and the results really don't reflect on the time spent on it.
Supplies that I used during this project were.
A computer
A 3-d printer
And filament
Step 1: Set Up the Base for the Mask.
First you put a half circle on the board and then make a smaller half circle and then you remove that from the half circle so that you have your base for your mask.
Step 2: Adding the Filter Parts.
You add in cylinders one bigger one in the center and two smaller ones off to the side to have the framework for the filter areas.
Step 3: Adding in the Place Where the String Area.
You take two rings put them together and attach them to the side.
Step 4: Add in the Part That Seals the Top of the Face.
You add in multiple round roofs to the top of the mask to prevent you know pollutants from coming in from the outside.
