Introduction: Top 5: Unique Ways to Open Bottles Without an Opener
Five great ways to open any beer or soda bottle when you don't have a bottle opener handy. From car keys and doors to belt buckles. You'll never have trouble opening another bottle!
When you're finished enjoying this instructable, check out my website for more of my written how-to's and tutorials or visit my YouTube page and watch more of my fun and informative videos.
My website: TheBestHobbiesBlog.com
My YouTube channel: YouTube.com/TheBestHobbiesBlog
Step 1: Watch This Video!
It's only two minutes long and you can watch me demonstrate and explain each of these bottle opening techniques.
Step 2: Another Bottle
If you want to get a bottle open chances are you'll usually have another bottle handy. I was skeptical of this method when I had first heard about it. But as it turns out this is both an effective and efficient means of bottle cap removal.
Hold one of the bottles upside down at a slight angle. Press both of the caps together and then pinch them between your palm and fore finger. Squeeze your hand into a fist and slowly increase the angle of the top bottle. Within seconds the top will pop off of the bottom bottle and you'll be ready to enjoy your refreshment.
Step 3: Key
House keys! Car keys! Any keys! If you don't have a set of keys on you, someone will!
Pinch the key between your thumb and the bottle with the "teeth" of the key just under the cap. Rotate the key so that the "teeth" angle upwards, bending the edge of the cap outward. Now just apply some upward pressure with your thumb and the cap should pop right off.
Step 4: Car Door Latch
A few people may not have the thumb or hand strength to open a bottle using their keys. No worries, all is not lost! The latch of your car door is actually the easiest way to open a bottle.
Just press the top of your beverage container against the latch and apply some downward pressure. It's super simple and easy enough to do with just one hand.
Step 5: Belt Method
What's that? You only have one bottle... You didn't bring your car... You've lost your keys... Just use a belt!
Take off your belt and re-fasten it. Tuck the tongue behind the buckle then place it flat in the palm of your hand. Hook the bar that fits into the sizing holes under the lip of your bottle cap and with a quick flick of the wrist pop it right off.
Step 6: Second Belt Method
Belts are basically bottle openers that hold up your pants.
If you have the right type of belt you can also use the metal loop that holds your belt tongue in place to get at that fizzy goodness. Just rest the loop under the lip of your bottle cap and then flip the buckle forward. This is actually even easier than the first belt method, assuming your loop is the proper shape and material for the job.
Step 7: How Would You Do It?
Thanks for reading my instructable! There must be thousands of unique ways to open bottles that don't have twist-off tops. Let me know in the comments the coolest way you've ever seen it done, or ask if anyone has ever tried a technique you're unsure of.
Don't forget to check out the links in the intro section of this instructable for my website and YouTube channel. I post to both regularly with fun projects, how-to's, tutorials, top 10 lists, and more!
