Introduction: 5 Camping Uses for Trash Bags
Here are 5 uses for a garbage bag when camping. These are all easy to do and will only cost you a couple of bucks.
Step 1: Use It As a Pack Cover
There's no need to buy a $30 pack cover. All you need is to slip a garbage bag over your backpack to keep your stuff dry.
Step 2: An Emergency Shelter
You can quickly set up this very cheap and easy emergency shelter with only a garbage bag and some rope.
Step 3: A Ground Cloth
Weather to sit on or to lay down on you can set a garbage bag down on the ground to keep yourself off it. You can even cut the seams/sides of the bag to double the size.
Step 4: Keep Your Feet Dry
Line your sock with a plastic bag and even if your boots are all soaked through you can still keep dry feet using this simple trick.
Step 5: A Pack Liner
Just slip a garbage bag in your backpack before putting your gear in so if your backpack gets soaked you can still keep your gear dry.
