Introduction: 5 Easy Steps to Convert a PSD to Wordpress Template
About: Deepa, a technical writer with SilverTouch, who now devotes her time in advising its clients to hire dedicated developers. She offers information as well as tips and latest trends in this domain. Her love for …
You have a PSD file that your designer sent, which now needs to be incorporate in your Wordpress website as a theme. Now, it is on you to convert the file from PSD into a Theme that Wordpress can comprehend. So, how would you perform the task? Here are five simple steps that will help you in getting through this conversion.
Slice the PSD file
The first step is to convert by slicing the design file, which in this case is a PSD file. The sliced files are then segregated into different groups namely header, footer, navigation bar, sidebar etc. Adobe photoshop and many such tools are available for slicing the image file.
Create HTML and CSS Versions
Once you have performed Step one and segregated the design file into several components, you have converted it into Wordpress compatible theme design. Employ the various CSS codes, HTML and XHTML semantics to this converted piece of design.
Convert to Wordpress Compatible Theme
Your file, segregated into different segments, has been optimized for Wordpress. The different markup conversions suitable for the image have also been instilled into the image. Now, this marked-up image will be finally converted into Wordpress compatible theme and uploaded to Wordpress interface.
Adding the Wordpress Tags
Once you have received the different markup elements, and introduced them to Wordpress, you will find that it is broken down into a PHP structure specifically designed for Wordpress. To achieve the basic functionality, add the appropriate internal functions as well as Wordpress tags. Once, you are done with this, you will have a functional theme loaded with necessary functionalities
Adding Some More Functionalities
With the above mentioned four steps, you have a functional Wordpress website. With some useful and dynamic plug-ins you can add in some more improvisations to the website.
Author Bio:
Deepa is a passionate blogger associated with Silver Touch Technologies., a leading Offshore WordPress development company. She loves sharing information regarding WordPress tips & tricks. If you are looking for Hire WordPress Developers in India then just get in touch with her.
