Introduction: 5 LED CHASER USING a TRANSISTOR
MATERIALS USED
1)BC547 TRANSISTORS 5NOS
2)5 LED
3)100 MFARAD CAPACITOR 5
4)220 OHM RESISTOR 5
5)10k RESISTOR 5
6) 9V POWER SUPPLY
Step 1: FIX 5 TRASSISTORS ON BREADBOARD
FIX 5 TRANSISTORS ON BREADBOARD SUCH THAT THEIS FLAT SIDE FACES AGAINST YOU.
Step 2: CONNECT RESISTOR
CONNECT BASE OF TRANSISTOR TO 10K RESISTOR AND CONNECT OTHER END OF RESISTOR TO POSITIVE RAIL
Step 3: INSERT LED
CONNECT CATHODE OF EACH LED TO THE COLLECTOR OF EACH TRANSISTOR AS SHOWN IN IMAGE
Step 4: CONNECT 270 OHM RESISTOR
CONNECT ANODE OF LED LED TO THE 270OHM RESISTOR AND CONNECT OTHER END OF RESISTOR TO POSITIVE RAIL.
Step 5: EMITTER TO NEGATIVE RAIL
CONNECT EMITTER OF TRANSISTOR TO NEGATIVE RAIL.
Step 6: ADD 100 MICROFARAD CAPACITOR
CONNECT ANODE OF CAPACITOR TO THE EMITTER OF FIRST TRANSISTOR AND CATHODE TO THE BASE OF SECOND TRANSISTOR. CONNECT 5TH CAPACITORS CATHODE TO THE BASE OF FIRST TRANSISTOR.
Step 7: FIRE UP
CONNECT 5V OR 9V POWER SUPPLY
