Introduction: Unusual Life Hacks of Super Strong Neodymium Magnet
About: So basically i am a crazy person, who loves to think the most odd way ever possible,who makes what he thinks and also let other also make those . Check out my crazy projects if you like do follow me :D
Neodymium magnets are super strong and come in a variety of shapes and sizes.
Last week I showed in my Instructables how I salvaged some of them from an old DVD-ROM drive.
We saw that in each Drive there are two such magnets.
This week I will share some good life hacks that I think are really incredible , and you can use it to simplify your life .
If anyone has some other cool hack make sure to share them in the comments section.
You can watch this video if you have less time
Also make sure you subscribe to the channel
https://www.youtube.com/c/PrajjwalNag
Step 1: Replace Paper Clips
If you don't have free magnets don't worry you can buy them from this link
http://goo.gl/DhHsHm 2$
http://goo.gl/R6qJSq
Paper clip or paper weight are commonly used to stick papers together but Carrying them can be hectic sometimes
here is a hack that will help you hold paper easily .
This is the magnetic paper clip helps you to hold your papers
Step 2: Key Chain Hanger / Tool Hanger
I usually lose my keychain a lot . so I decided to just snap it on the holder when I come in the room.
Using a magnet and small double sided tape I made a keychain holder for my keychain .
Taking it to the next level
This hack can also work with all you hand tools ,
Tested this with screwdrivers, pliers, Even A MEASURING TAPE :P
Step 3: Battery Connector
The Best and the most useful hack is to use it as battery connector
When would you need to used magnets as connector .
  • In a case of Li-ion battery
  • In case you want to make shield that snap on boards
  • U don't have a connector
Step 4: Snack Pack Sealer
Now and then I face the problem that I start eating a snack and I don't know what to do in half way .
I either need an elastic band to wrap it to make it air tight again.
The irritating part of using bands is finding a perfect band for the task is like finding water in a desert .
And even after getting the treasure it tears.
Here instead fo bands I am using two magnets to make it an air tight container.
That is a real time saver.
Next time you go out on trips take those magnets with you.
They will help you a lot.
Step 5: Laptop Hibernator
Have you ever thought to put ur lappy to sleep without even touching the button , this can be easily done with these magnets.
This magnet being small and light is easy to keep on the laptop.
Does it work on all laptop ?
Yes ,all laptop have a hall effect sensor to turn itself into hibernation while the screen is folded try to find where it is located to hack it next time .
Step 6: Stick a Note
This one is evergreen and lovely .I guess it has been used since ages.
Are you tired of the stick note that doesn't stick at all ?
Forget using those ,use a couple of magnets to attach notes on ur refrigerator.
Or maybe your iron table or may be iron almirah.
Tell where you will stick it .
If you like these hack and want more subscribe to our channel.
and
like on us
https://www.facebook.com/makewithRex/
