Introduction: 5 Methods: Guide to Drying Beautiful Flowers
Want the flowers your father or husband gave you to last forever? Or just want to dry some for crafts? Try these 5 different techniques!
Air Drying Technique:
Flowers
String
Scissors
Stick or Hanger
Microwave Technique:
microwave
microwave-safe container
flowers
silica gel
fine-tip brush
acrylic spray
Desiccant Technique:
You need any of these listed below:
and flowers
Baking Technique:
Oven
Flowers
Pressing Technique:
2 books (or any heavy thing)
Flowers
Step 1: Air Drying Technique
  1. Excess foliage should be taken off of flowers
  2. Cut the stems to your desired length (shouldn't be shorter than six inches).
  3. Flowers should be hung individually or stems should be rubber-banded together to hang bouquet.
  4. Hang flowers in a dark, dry area with good circulation. With string secure the bottom of the flowers’ stems to a hanger so that they hang upside down to dry.
  5. For Flowers to better retain their color in the drying process, make sure no sunlight can get at them when they are cut
  6. Flowers should hang for two to three weeks until removed, make sure they are completely dry.
  7. Once you remove flowers from hanger spray with unscented hairspray for protection.
Step 2: Microwaving Technique
  1. Get a microwave-safe container to hold both your flowers and fit in the microwave. Don't use a dish that will later be used for food.
  2. The bottom of the container should be covered with about an inch or two thick of silica gel, a bit more for larger blossoms.
  3. Place the flowers blossom-up in gel and then pour more gel over the petals. Pour gently, or use your hands, so that petals don’t get flattened.
  4. Place the uncovered container in the microwave. Microwave temperature and time will vary according to the type of flower, so this step requires a bit of trial and error. Start the microwave on one or two heat levels above defrost for 2-5 minutes. Roses can withstand more heat, while daisies are best dried at lower temperatures.
  5. Check your flower’s progress in the microwave after about a minute, and then every 30 seconds. Increase heat and time as needed.
  6. Once flowers have completely dried, open the microwave and immediately cover the container.
  7. Remove the covered container from the microwave, open the top a quarter of a centimeter, and let it sit for 24 hours.
  8. Clean the gel from the petals with a fine-tip brush and then mist with an acrylic spray (also available at craft stores).
  9. Finally, display or use your dried flowers in craft projects as you like.
Step 3: Desiccant Technique
  1. Submerge your flowers in a bed of desiccant—any of the things listed below:
2.Let them sit for a few weeks to remove their moisture.
3.This method takes longer than microwaving your flowers, but it can preserve their color more effectively.
Step 4: Baking Technique
  1. Put your blooms in the oven at a low temperature
  2. Bake them for a couple of hours.
  3. This is a quick method for drying flowers, but you may lose a lot of petals in the process. Also, this method is not the best for preserving the color of your flowers.
Step 5: Pressing Technique
  1. Use a heavy object (such as 2 books) to squeeze the moisture out of a flower.
  2. Put the flower inside a book or in between 2 books.
  3. Take out after about 2-4 weeks.
  4. Pressing is an effective way to dry flowers for crafts, artwork, or stationery.
