Introduction: 5 Minute Syringe Pen
This instructable will show you how to make a syringe pen in 5 minutes or less. The idea of making this just popped up into my head when I saw this syringe which was lying around in my house for a while (of course clean and without a needle). Please clean out the injections before using them for this instructable. These syringes were for pet use. Enjoy the instructable.
Step 1: You Will Need
For this instructable you will need
1. scissors
2. epoxy
3. a small stick
4.a pencil
5.a syringe washed with soap and anti bacterial
6. a cheap pen which is easy to take apart
you usually get them in hotels and stuff.
1. scissors
2. epoxy
3. a small stick
4.a pencil
Step 2: Take the Pen Apart
To get to the pen mine you will have to take your pen apart by either pulling the two ends
away from each other or if you have a different type you can just screw it apart. You will not need anything from the pen for this project except for the pen mine.
Step 3: Cut the Pen Mine
The next step is to cut the mine closest to the ink. Dont cut it too close or the ink will spill.
Step 4: Push the Pen Mine In
The next step will be to push the pen mine into the syringe as far as you can with the stick. Then lay the thing you push into it beside it and cut it to the length you want it to stick out the end.
Step 5: Glue It In
The next step will be to squeeze out a bit of epoxy and mix it hard. When you are done with mixing put a bit on the thing you push in. Dont use too much glue! or it will run down and it wont give the effect.
Step 6: Final Product
Thank you for taking your time and looking at my first instructable! I hope you enjoyed it. Feel free to comment if you have any questions about my instructable.
