Introduction: 5$ USB Fan!
Build your own USB fan! Will work with:
- PC
- Mac
- Ipod charger
- Any other USB charger
And all that for under 5$!
- PC
- Mac
- Ipod charger
Step 1: Materials
What you'll need is:
- Super glue
- USB connection
- Wire
- a small piece of metal (1.5-2 CM long)
- 2 small magnets or a big one
- a 5 Volt motor
- Motor top
You can use a old USB cable instead a wire and USB connector.
- Super glue
- USB connection
- Wire
- a 5 Volt motor
- Motor top
Step 2: Creating the Fan
In order:
1. Attach the motor to to the motor.
2. Solder the wires to the the + and - points.
3. Glue the wires to the side. This way the wires wont touch each other. Make sure you DONT glue the little metal part or it wont turn.
4. Bend the metal so you can attach it to the motor.
5. glue the magnets to the back of the metal.
Step 3: Creating the Bottom
FIRST OF ALL: YOU HAVE TO CHECK WICH SIDE IS + or - AND THEN SOLDER
When you solder make sure that the wires are close to each other so they can short circuit.
Step 4: Final Product
This is the final product.
