Introduction: 5-minute Sun-Shader
In this instructable, we will show you how to make an easy 5-minute sun-shader.
Do you put a big sun reflector on your car's dashboard when you park your car?
When you come back, do you think that your car is still ranging with heat?
The problem is that your car windows are not well shaded, or not shaded at all.
Blazing sun is shining in your car trapping heat that doesn't come out.
Why not make yourself an easy sun-shader and keep your car cooler once and for all?
Follow this instructable made by Dominick Lee.
Step 1: Things You Will Need
You will need cheap household supplies including:
-2 pieces of white copy paper
-A piece of aluminum foil
-Some Glad Wrap
-Tape
-Scissors
-Some Glad Wrap
-Tape
-Scissors
Step 2: Add the Aluminum Foil
First, cut a piece of aluminum foil which is slightly bigger than the copy paper.
Then, place the copy paper on the aluminum foil and wrap the foil edges on the copy paper.
Step 3: Break Out the Glad Wrap!
Place the wrapped copy paper on the Glad Wrap and tape all four edges until it all fits snugly on the copy paper.
Step 4: Final Touch
If you want to make the Sun-shader look nicer, then make loops of tape on the back of the copy paper and apply the second piece of copy paper on the looped tape.
There you have it! You very own Sun-shader!
You can use bigger pieces of paper, foil, and glad wrap for a bigger sun shader!
Enjoy!
