5.00 Ipod Amplifier
Intro: 5.00 Ipod Amplifier
5.00 IPOD (portable audio whatever) Amplifier.
I found these at Big lots and picked up a couple, they are 5.00 and you can remove the portable battery powered amplifier to use on whatever you choose.
It runs off 4 AAA Batteries and you can make the lil battery powered speakers sound like a lil boom box.
STEP 1:
Inside there is a lil amp ran to a single speaker. Its screwed in from behind.
STEP 2:
Remove the amp:
Carefully cut around the amp, once you can get your hand behind it you can unscrew it.
You also need to cut the wire going to the speaker.
The 1st time I did this I really over cut, you can just go around the amp and then have a descent carry case left over.
Be careful not to cut the wire closer then you want to, it runs up in the case. (up and left)
STEP 3:
I used a 3.5mm Stereo Plug and ran the wire the formally went to the speaker and soldered it to a 3.5mm Stereo Plug to run to portable speakers.
I also just rolled up the other wire that will run to the IPOD, it has the green shrink wrap on it.
There is a "share port" but it is not amplified.
The unit runs off 4 AAA Batteries.
STEP 4:
I have a lil case that holds my IPOD and the amp together, I have the speaker out so I can run it where its needed.
On my bicycle I hang it from the mirror and its a great lil wanna be boombox.
STEP 5:
Ive made 2 now, the 2nd just to clean it up and for 5.00 figured a back up is good. I saw similar units at Frys starting at 50.00. And I think Frys is usually the cheaper option.
22 Comments
jsaen33 13 years ago
shayboaz 14 years ago
lisaf82168 14 years ago
n0ukf 14 years ago
zvillesurfer 14 years ago
fish2find 14 years ago
homemovies64 14 years ago
n0ukf 14 years ago
edfel01 14 years ago
n0ukf 14 years ago
For more sound, you need to push more power (higher output amp) or more sensitive speakers. Pushing 1W of power into a 93 dB 1W/1m SPL (sound pressure level)speaker would sound about the same as pushing 10W of power into a 83 dB 1W/1m SPL speaker (of the same physical cone size).
I have noticed that a smaller speaker will sound louder when it really isn't, due to the harsher sound it makes compared to a larger speaker which would be heard better in a greater area without actually sounding loud
old_bass_masta 14 years ago
jumper985 14 years ago
bugmenot 14 years ago
bobbyderf123 14 years ago
cronos_artist 14 years ago
Corpy 15 years ago
