Introduction: 5.1 Channel Preamplifier
About: Embedded systems engineer, amateur radio operator, and amateur astronomer.
This project introduces a digitally controlled 5.1 channel audio preamplifier system. This amplifier is specifically designed to increase the gain of the multi-channel PC sound cards.
The main reason for building this amplifier is the limited gain received from the ASUS Xonar AE sound card with the Creative Inspire T6300, 5.1 surround speaker system. Before switching to this soundcard, we had a Creative Sound Blaster Z card which provided good audio output with the above-mention speaker system. The key motivation of building this amplifier is to solve these gaining problems.
Capacitors
  • C1, C10, C11, C12, C13 : 0.1µF (SMD 0805) - Qty: 5
  • C2, C3 : 4700µF - Qty: 2
  • C4, C5 : 0.1µF - Qty: 2
  • C6, C7, C8, C9, C21, C22 : 10µF - Qty: 6
  • C14, C15, C16, C17, C18, C19, C20, C23, C24, C25, C26, C27, C28, C29, C30, C31, C32, C33, C34, C35, C36, C37, C38, C39, C40 : 1µF - Qty: 25
Resistors
  • R1, R2, R3 : 0Ω or 30 S.W.G copper wire - Qty: 3
  • R4, R7 : 390Ω 1/4W THT resistor - Qty: 2
  • R5, R6 : 1KΩ 1/4W THT resistor - Qty: 2
  • R8, R33, R34, R35, R36, R43, R44 : 22KΩ - Qty: 7
  • R9 : 470Ω - Qty: 1
  • R10, R11, R12, R13, R14, R29, R30, R31, R32, R41, R42 : 10KΩ - Qty: 11
  • R15, R16, R17, R18, R19, R20 : 1MΩ - Qty: 6
  • R21, R22, R23, R24, R37, R38 : 100KΩ - Qty: 6
  • R25, R26, R27, R28, R39, R40 : 2.2KΩ - Qty: 6
  • RV1 : 50KΩ (SMD TC33) Potentiometer - Qty: 1
Connectors and sockets
Semiconductors
Switches
Miscellaneous
Step 1: The Contents of the Circuit
This preamplifier consists of six TL074/TL072 preamplifier stages and PT2258 electronic volume control. The input stage of this preamplifier consists of six TL074/TL072 buffer stages. The PIC16F886 microcontroller manages the PT2258 electronic volume control IC. All the volume levels and menu options are displayed on HD44780, 16x2 character LCD screen.
All the menu navigations and volume controlling can perform using a 5-pin, EC11 series rotary encoder. An additional push switch provides to mute and unmute the audio outputs.
This preamplifier is an open hardware project. All source codes, KiCAD design files, and compiled binaries are available at the GitHub project repository. The complete documentation of this project is available at the GitHub project wiki.
Step 2: Firmware
The firmware of the PIC16F886 has been developed using Microchip's MPLAB XC8 toolchain. The provided firmware supports two volume control modes. In default mode, the user can control simultaneously control volume levels of all 6-channels. In the second mode, the user can control the volume of the individual channel. These volume control modes can select from the menu system.
The firmware can directly upload to the MCU through the ICSP terminal provided on the PCB.
Step 3: Printed Circuit Board
The PCB of the preamplifier is designed as a double-sided board. Many of the components used in this PCB are in the form of surface-mounted packages.
We use a dual-line package for the PT2258 due to the difficulty of obtaining the SMD package.
The provided PCB design contains a preamplifier, buffer stages, digital volume control circuit, driver circuit, and power supply unit.
The project was sponsored by PCBWay. The accurately configured PCB of this preamplifier can directly order from PCBWay through their website. The dimension of the PCB is 151.45 × 50.76mm. The video related to this article clearly shows the steps of assembling, flashing, and mounting this preamplifier.
Step 4: Power Supply
The recommended transformer for this circuit is 6V×2 (1A) step-down transformer. The given power supply circuit consists of three voltage regulators, including LM317, LM337, and L7805. Both the LM317 and LM337 regulators are configured to provide 4.5V dual-rail output.
Step 5: Final Steps
As mentioned at the beginning of this article, we successfully tested this preamplifier with an ASUS Xonar AE sound card. This preamplifier provides significant and clean output with the above-mention sound card and speaker system. We construct our prototype build using a commonly available 230mm × 150mm × 84mm ABS project box.
