555 AM Transmitter
Intro: 555 AM Transmitter
This is a very simple easy to make AM transmitter if you don't want to use inductors or capacitors and don't mind not having extreme power. The best part is everythinf you need to build it is at Radio Shack.
STEP 1: Building the Circuit
Once you have all the parts the circuit is very simple to construct (on a breadboard anyway). The simple seven component schematic is below.
A decoupling capacitor is needed for battery operation =]
STEP 2: Tunning the Circuit
Once its assembled you have to tune it and then adjust the audio in ground for optimum audio level and clarity. The pot on the left (or the one thats hooked to the IC) adjusts the frequency. It really doesn't adjust it that much ±30 kHz and is for fine adjustment only. Since the frequency is near 540 kHz sweep the radio and the right pot (audio ground). Once you hear it your done, but the radio has to be a little loud because there is no pre amp on the transmitter
STEP 3: Specs and Troubleshooting
Range: 2m
Power: 5-15V
Freq: 530 kHz - 640 kHz possibly higher
Troubleshooting:
If your tuning it for the first time do not use a portible radio it dosn't work well wit them.
If you know its getting power and you can't tune in try stepping away from it or touching parts of it to act like an antanna (I coulden't get wire to work)
Also it might not be enough amps i never mesured how many it took, but it likes computer power supplies and 9.6V packs.
If you want better audio put an inductor between the IC's output and audio in.
Power: 5-15V
Troubleshooting:
52 Comments
PRO DR MR BOB 9 years ago
What dose 2m mean is it 2 meters or 2 miles in the specs of the trasmiter
yousef777 6 years ago
mean is it 2 meters
bo'connor1 9 years ago
By portable radio, do you mean battery powered or socket powered?
cbatenga 10 years ago
jazzzzzz 10 years ago
LSD3 11 years ago
jazzzzzz 11 years ago
LSD3 11 years ago
If your going IC the 74HC5555 is quite nice(89MHz at 25°C).
The problem is most IC's are going to give a square wave with a lot of harmonics and not so much power. A Colpitts or Hartley would be better. Also easy to get componants for.
Do you have microcontrollers and a programmer for the addressing?(if not i have a backup plan). Are you using a PIR sensor for detection?
rob0t 11 years ago
Thanks Lectric Wizard for other circuits, always good to have a few to compare.
Good job Jazzzzzz.
But I fail ;).
Audio pot:
__
[_]
| | |Ground
| \+5v
audio+
Audio- to 3.
Yes?
Since audio is technically AC it will depend on the audio source.
If the source crosses zero (true ac) it wont make a difference I would just try it both ways, it is the best way to be sure
rob0t 11 years ago
I tried.. all the ways! I was having trouble with audio jack, which was the live pin, and what was just a pin (to fix).
The audio pot really changes volume too, which is cool.
Now, why would you think my 5v setup was not working?
Antenna problem, i.e. I was too far, and using 9v boosts anyway the signal, so I assume the 5v was for me too little (too far).
I will have to try 5v again, very close, on top of radio.
Or, 100uF cap between output& gd might help.
Cool anyway!
My first working project in MW! :)
Thanks Jazzzz.
what were you using as a 5V source?
rob0t 11 years ago
rob0t 11 years ago
I used 9v (instead of 5v) and voila!
Cool! :)
Lectric Wizard 11 years ago
jazzzzzz 12 years ago
I will post it as soon as possible
