Introduction: 555 PWM Motor Controller
I often face a situation when I want to test a motor, sometimes for my projects, sometimes just to see if it works. The simplest solution is just to connect it to a battery or some kind of power supply and that's ok but what if you want to control motor speed for example by PWM? You have to use Arduino with motor controller, connect all of that, program it and then you can use it, but that's a lot of work. What if there is simpler solution for that. So I started thinking if I can use something else then microcontroller to create PWM signal, and I thought about world's most popular integrated circuit (IC) the 555 timer. I already made few things with 555 timer like my useless machine, so I thought that it can also be used to create a 555 PWM motor controller. After quick research on the internet I found out how to create that kind of circuit, it's a little bit tricky because it's not a standard configuration of 555 timer. Thanks to this small project I can test my motors and prototype new projects on the go everywhere I am. So are you ready to see how I made it? Let's dive in to it!
Quick note from a sponsor of this project:
JLCPCB 10 boards for $2: https://jlcpcb.com
Step 1: Parts
For this project you will need just few components, you can buy them in local shop or online, here are links to banggood, you can buy them really cheap. Most of the links are bigger quantities of those elements but you will definitely find use for them in future projects.
- 555 timer
- IRFZ44N MOSFET
- 10k potentiometer
- Diodes
- 5mm screw terminal
- DC jack socket
- 1,2k resistor
- 10nF capacitors x2
Step 2: Schematic, PCB and Breadboard
Above you can find schematic of this circuit if you want to connect that on a breadboard. If you want to make PCBs you can also find there .ZIP with all of the files including schematic, PCB layout and gerbel files. This PCB was designed in KiCAD - free software for designing PCBs. If you would like to buy PCB for this project you can check out my Tindie store, there is a PCB for this project and few other PCBs for my projects. Here is link to my store: https://www.tindie.com/stores/Nikodem/
Step 3: Soldering
There is not a lot of components to solder, all of them are THT so this project is beginner friendly, perfect if you want to learn soldering. Just start with the smallest components and cut out legs of them if they are too long then move on to the bigger components and so on. Soldering shouldn't take more than 20 minutes. Be careful while using soldering iron, it's very hot, you don't want to touch it.
Step 4: Connect Motor
Once soldering is done you can connect a motor to screw terminal on the PCB. If you don't have a motor with wires you have to solder two wires to it's connectors and then screw the other ends of cables to a screw terminal. Use a flat screwdriver for that and be gentle it's easy to break those small components.
Step 5: How to Power It?
Good thing about 555 timer is that it can be powered with a voltage from 4,5V up to 16V. For bigger motors I am using 12V power supply with a DC jack (standard DC jack, the same that is used in Arduino UNO), you can use smaller and bigger voltage within this range, but remember about nominal voltage of your motor. If I have to power smaller motors I am using batteries or my lab bench power supply.
Step 6: Play With It!
The last step is the best one! Just have fun with your new project :) I hope it gave you a lot of fun and will be useful for you. I will definitely use it as a tool in my workshop. Don't forget to leave a comment down below and <3 if you like my project. If you will build one, share it on social media and tag me! Thanks for reading :)
Follow me on social media:
YouTube: https://goo.gl/x6Y32EFacebook: https://goo.gl/ZAQJXJ
Instagram: https://goo.gl/JLFLtf
Twitter: https://goo.gl/JLFLtf
Happy making everyone ?
